how to exit From Rxboot exe mode in cisco 2511 router
maninthemirrow
hello friends
My Cisco 2509 access server was working fine until yesterday when l turn it on. it when into the BxBoot mode and cant get out of it. can anyone help please
thank.
Can you try folowing this link as it starts with the > prompt just like you have explained.
http://www.cisco.com/c/en/us/support/docs/routers/2500-series-routers/15078-recovery-c2500.html
Alex
Regards, Alex. Please rate useful posts.
acampbell
This sounds like your IOS iage in yor flash is corrupt
The RXBoot image offer some support for tftp etc
so you should be able to renew your flash IOS.
Have a read at this link:-
http://www.cisco.com/c/en/us/support/docs/routers/2500-series-routers/10252-13.html
Alex
helllo
thanks for the link, but it does not allow me to use the copy tftp to flash although l can ping the tftp server there is no command to copy etc.
if l first connect to CLI  l can only see ">" if l press "?" "Image1 "  is the list of commands . if l press "B" then it will take me to the Rxboot (images 2)and allow me to login, but cannnot do anything. please take a look at the images 343.txt
thanks
Alex
hello Acampbell
just this two command and it works just fine was able to come out of the Rxboot exe mode.
thanks.
