how to find the suitable IOS for cisco switches
gopi_b4u2003
Hi all,
can anyone help on this .I want to find out some advanced ios version link ssh,bgp and some features. where can i find that. if i logging into the software advisor it display as forbidden error. please solve this issue.
Thanks in advance
Gopianth.L
Reza Sharifi
Hi gopinath,
Use the feature navigator to help you determine the features you need.
Here is a link to it:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Reza
Reza Sharifi
Hi gopinath,
Reza
thank you very much.
Gopinath.L
Lucien Avramov
Level 10
Level 10
For SSH you need a crypto image (k9).
You may want to go with enterprise with crypto or advanced ip services with crypto.
Look at the feature navigator as indicated earlier to clarify your doubts.
