07-27-2019 11:59 AM
I got cisco 3850 2 switches and connected in the stack.
It's observed that the version of the switches stack-ports is different. Is there any issue and how to update it.
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48P 16.3.8 CAT3K_CAA-UNIVERSALK9 INSTALL
2 56 WS-C3850-48P 16.3.8 CAT3K_CAA-UNIVERSALK9 INSTALL
Switch# Role Mac Address Priority Version State
*1 Active 682c.7b6d.e280 15 V07 Ready
2 Standby 6cfa.894f.8b80 1 V03 Ready
Solved! Go to Solution.
07-27-2019 01:29 PM
Hi there,
They are hardware version numbers. In all my years I've never seen an upgrade caveat mentioning incompatibility between different hardware versions.
You should be fine to upgrade.
cheers,
Seb.
07-27-2019 01:29 PM
Hi there,
cheers,
Seb.
07-27-2019 05:35 PM
07-28-2019 02:01 AM
Not that you need much worry on that, you an upgrade the stack (make sure you read the realease notes the one you looking for upgrade.
here is the steps i follow ;
1. take the configuraion backup out of the box.
2. read the realease notes and compatability and features you running.
3. upgrade in maintenance window/(since switch required reboot,)
