02-09-2021 11:50 AM - edited 02-09-2021 11:51 AM
Hello All,
We have WS-C3750X-12S with 2 Fans , one fan of the show enviroment shows as faulty , i would like to replace it with another FAN , how can i get the exact name of the model number of this Fan ? it doesn't show on the "show inventory " , appreciate your support , also i couldn't check it physically as it's in a remote location
Solved! Go to Solution.
02-09-2021 12:00 PM
Have a look at this link:
table-10 in this link has the part number:
https://www.cablesandkits.com/accessories/switching/cisco-fans/c3kx-fan-23cfm/pro-7963/
02-09-2021 12:00 PM
