Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi,I am trying to set up an SSH connection to my switch, but right now there is some lower level problem. I have set up my FastEthernet0 interface to ip address dhcp and the command show interfaces FastEthernet0 shows the correct address. Even if I t...
limex by Level 1
  • 72 Views
  • 5 replies
Hi,I have been testing MST in my lab which has 3x Cisco Catalyst WS-C2960CG-8TC-L switches.I configured only MST and LACP on each switch and connected them in the ring topology. Test is to see how much time it takes for convergence in such conditions...
On my Cisco 2960CG running 15.2(2)E10 when I run command show ip igmp snooping detail, among other things I see that IGMPv3 snooping (minimal) is enabled. Why is this feature called minimal? What is missing from normal v3? Is there any official Cisco...
Resolved! Catalyst 9500-16X
Hello everyone,I am a student, and for a paper i am doing i was wondering if Catalyst 9500-16X was able to do VPN IPSEC as a client, connecting to a cloud VPN IPSEC server. The use case is a Collapse Core topology and i would use 2 C9500-16X as the c...
Hello,Studying for my CCNA and I thought I'd practice some basic configurations, such as router on a stick. I setup 4 PC's (each representing an imaginary number of hosts) each with a vlan attached to a switch leading to a router, with the link betwe...
