How to ping to Seperate Vlans from 2 Diffrent Switches
Hari Kumar Raja
Hi ,
I have a 2 Cisco 3750 Switches in my company network in 2 locations ( 1 Location 10.10.1.0 and other location 10.10.0.0 ) , i have created one more vlan in my primary site and give vlan ip as 10.10.2.0 , now i want to ping 10.10.0.x subnets and systems from 10.10.2.0 network viseversa , but i am unable to ping any host in 10.10.0.x , can any one help me on this.
Hari
2 Accepted Solutions
Hi Hari,
Glad to hear that this is working as expected. Which ip address did you point your static route to? Is it to 35 or 36?
Najaf
Hi Hari,
Is your rquirment is to allow only ping from 10.10.2.x network to 10.10.33.x network? None of the other ip subnet should not be able to ping 10.10.33.x?
You could use an extented ACL to achive this and apply the ACL on VLAN 33.
Najaf
13 Replies 13
Hari Kumar Raja
Can any one help me pls on this , i am not femiler with cisco , i have a 2 routers in both locations and i am able to trace 10.10.1.0 from 10.10.0.1 and not able to trace 10.10.2.0 from 10.10.0.1 , belwo are the trace details and routing tables from both switches.
Phoenix-VSEZ-CORE#traceroute 10.10.1.36
Tracing the route to 10.10.1.36
  1 10.10.0.3 8 msec 0 msec 9 msec
  2 10.10.24.1 0 msec 8 msec 8 msec
  3 10.10.1.36 9 msec *  9 msec
Phoenix-VSEZ-CORE#traceroute 10.10.2.36
Tracing the route to 10.10.2.36
  1 10.10.0.3 0 msec 0 msec 0 msec
  2 10.10.24.1 0 msec 17 msec 0 msec
  3 10.10.24.1 !H  *  !H
From 10.10.0.1 switch :
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.33.5
ip route 10.10.0.0 255.255.255.0 10.10.0.3
ip route 10.10.1.0 255.255.255.0 10.10.0.3
ip route 10.10.2.0 255.255.255.0 10.10.0.3
ip route 10.10.5.0 255.255.255.0 10.10.0.3
ip route 10.10.25.0 255.255.255.0 10.10.0.3
ip route 10.10.32.0 255.255.255.0 10.10.0.3
From 10.10.1.36 Switch :
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.1.43
ip route 10.10.0.0 255.255.255.0 10.10.1.199
ip route 10.10.2.0 255.255.255.0 10.10.1.199
ip route 10.10.25.0 255.255.255.0 10.10.1.35
ip route 10.10.32.0 255.255.255.0 10.10.1.199
ip route 10.10.33.0 255.255.255.0 10.10.1.199
ip route 10.10.34.0 255.255.255.0 10.10.1.199
ip route 10.10.35.0 255.255.255.0 10.10.1.199
ip route 172.16.20.0 255.255.255.0 10.10.1.35
ip route 192.168.1.0 255.255.255.0 10.10.1.35
ip route 192.168.6.0 255.255.255.0 10.10.1.35
ip route 192.168.99.0 255.255.255.0 10.10.1.35
Thanks in advance
Hi Hari,
It would help if you could let us know how these devices are connected physically (i mean a diagram would help) along with show ip int brief output from the devices.
Looking at the trace it looks like the device which has ip address 10.10.24.1 doesn't have a route to 10.10.2.x network.
Hope that helps
Najaf
Hi Nijaf,
Thanks for your reply , as i told you i am a new user for this domain , as suggested by you i have added ip route in 10.10.24.1 and below are the modification details details , after adding the route i tried to ping 10.10.2.36 from 10.10.0.1 swtich and the resutl was below  , i tried to traceroute 10.10.2.36 from 10.10.0.1 and the result was below , but i am unable to ping any ip in 10.10.2.x network .
ip route 10.10.0.0 255.255.255.0 10.10.24.2
ip route 10.10.2.0 255.255.255.0 10.10.24.2
ip route 10.10.32.0 255.255.255.0 10.10.24.2
ip route 10.10.33.0 255.255.255.0 10.10.24.2
ip route 10.10.34.0 255.255.255.0 10.10.24.2
ip route 10.10.35.0 255.255.255.0 10.10.24.2
From 10.10.0.1 Switch ( 3750)
Phoenix-VSEZ-CORE# show ip int brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES NVRAM  administratively down down
Vlan31                 10.10.0.1       YES NVRAM  up                    up
Vlan32                 10.10.32.1      YES NVRAM  up                    up
Vlan33                 10.10.33.1      YES NVRAM  up                    up
Vlan34                 10.10.34.1      YES NVRAM  up                    up
Vlan35                 10.10.35.1      YES NVRAM  up                    up
FastEthernet0          unassigned      YES NVRAM  administratively down down
GigabitEthernet1/0/1   unassigned      YES unset  up                    up
GigabitEthernet1/0/2   unassigned      YES unset  up                    up
GigabitEthernet1/0/3   unassigned      YES unset  up                    up
GigabitEthernet1/0/4   unassigned      YES unset  down                  down
GigabitEthernet1/0/5   unassigned      YES unset  down                  down
GigabitEthernet1/0/6   unassigned      YES unset  down                  down
GigabitEthernet1/0/7   unassigned      YES unset  down                  down
GigabitEthernet1/0/8   unassigned      YES unset  down                  down
GigabitEthernet1/0/9   unassigned      YES unset  down                  down
GigabitEthernet1/0/10  unassigned      YES unset  up                    up
GigabitEthernet1/0/11  unassigned      YES unset  down                  down
GigabitEthernet1/0/12  unassigned      YES unset  down                  down
GigabitEthernet1/0/13  unassigned      YES unset  down                  down
GigabitEthernet1/0/14  unassigned      YES unset  down                  down
GigabitEthernet1/0/15  unassigned      YES unset  down                  down
GigabitEthernet1/0/16  unassigned      YES unset  down                  down
GigabitEthernet1/0/17  unassigned      YES unset  down                  down
GigabitEthernet1/0/18  unassigned      YES unset  down                  down
GigabitEthernet1/0/19  unassigned      YES unset  up                    up
GigabitEthernet1/0/20  unassigned      YES unset  down                  down
GigabitEthernet1/0/21  unassigned      YES unset  down                  down
GigabitEthernet1/0/22  unassigned      YES unset  down                  down
GigabitEthernet1/0/23  unassigned      YES unset  down                  down
GigabitEthernet1/0/24  unassigned      YES unset  up                    up
GigabitEthernet1/1/1   unassigned      YES unset  up                    up
GigabitEthernet1/1/2   unassigned      YES unset  down                  down
GigabitEthernet1/1/3   unassigned      YES unset  down                  down
GigabitEthernet1/1/4   unassigned      YES unset  down                  down
Te1/1/1                unassigned      YES unset  down                  down
Te1/1/2                unassigned      YES unset  down                  down
Phoenix-VSEZ-CORE#ping 10.10.2.36
Sending 5, 100-byte ICMP Echos to 10.10.2.36, timeout is 2 seconds:
Success rate is 0 percent (0/5)
  2 10.10.24.1 0 msec 0 msec 8 msec
  3 10.10.24.2 0 msec 17 msec 0 msec
  4 10.10.24.1 8 msec 8 msec 9 msec
  5 10.10.24.2 8 msec 9 msec 8 msec
  6 10.10.24.1 9 msec 8 msec 8 msec
  7 10.10.24.2 9 msec 8 msec 9 msec
  8 10.10.24.1 8 msec 8 msec 8 msec
  9 10.10.24.2 9 msec 17 msec 8 msec
10 10.10.24.1 8 msec 8 msec 17 msec
11 10.10.24.2 8 msec 8 msec 17 msec
12 10.10.24.1 8 msec 33 msec 42 msec
13 10.10.24.2 42 msec 42 msec 9 msec
14 10.10.24.1 9 msec 17 msec 16 msec
15 10.10.24.2 9 msec 17 msec 17 msec
16 10.10.24.1 17 msec 34 msec 16 msec
17 10.10.24.2 17 msec 9 msec 17 msec
18 10.10.24.1 17 msec 17 msec 50 msec
19 10.10.24.2 17 msec 59 msec 34 msec
20 10.10.24.1 17 msec 17 msec 16 msec
21 10.10.24.2 17 msec 25 msec 25 msec
22 10.10.24.1 25 msec 16 msec 25 msec
23 10.10.24.2 17 msec 16 msec 26 msec
24 10.10.24.1 25 msec 17 msec 25 msec
25 10.10.24.2 25 msec 16 msec 34 msec
26 10.10.24.1 25 msec 25 msec 25 msec
27 10.10.24.2 25 msec 42 msec 26 msec
28 10.10.24.1 25 msec 25 msec 34 msec
29 10.10.24.2 25 msec 26 msec 25 msec
30 10.10.24.1 33 msec 34 msec 25 msec
From 10.10.1.36 Switch ( 3750)
L3-PHOENIXCORP#sh ip interface brief
Vlan1                  10.10.1.36      YES NVRAM  up                    up
Vlan101                unassigned      YES NVRAM  up                    up
Vlan102                10.10.2.36      YES NVRAM  up                    up
Vlan103                10.10.3.36      YES NVRAM  up                    up
Vlan104                10.10.4.36      YES NVRAM  up                    up
Vlan105                10.10.5.36      YES NVRAM  up                    up
Vlan106                10.10.6.36      YES NVRAM  up                    up
Vlan107                10.10.7.36      YES NVRAM  up                    up
Vlan108                10.10.8.36      YES NVRAM  up                    up
Vlan109                10.10.9.36      YES NVRAM  up                    up
Vlan175                unassigned      YES NVRAM  up                    up
FastEthernet0          unassigned      YES NVRAM  down                  down
GigabitEthernet1/0/4   unassigned      YES unset  up                    up
GigabitEthernet1/0/5   unassigned      YES unset  up                    up
GigabitEthernet1/0/6   unassigned      YES unset  up                    up
GigabitEthernet1/0/7   unassigned      YES unset  up                    up
GigabitEthernet1/0/8   unassigned      YES unset  up                    up
GigabitEthernet1/0/9   unassigned      YES unset  up                    up
GigabitEthernet1/0/11  unassigned      YES unset  up                    up
GigabitEthernet1/0/12  unassigned      YES unset  up                    up
GigabitEthernet1/0/13  unassigned      YES unset  up                    up
GigabitEthernet1/0/14  unassigned      YES unset  up                    up
GigabitEthernet1/0/18  unassigned      YES unset  up                    up
GigabitEthernet1/0/20  unassigned      YES unset  up                    up
GigabitEthernet1/0/21  unassigned      YES unset  up                    up
GigabitEthernet1/0/22  unassigned      YES unset  up                    up
GigabitEthernet1/0/23  unassigned      YES unset  up                    up
GigabitEthernet1/1/1   unassigned      YES unset  down                  down
From 10.10.24.1 ( Router)
phoenixcorpoff881#sh ip interface brief
ocol
FastEthernet0              unassigned      YES unset  up                    down
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    up
FastEthernet4              10.10.24.1      YES NVRAM  up                    up
Vlan1                      10.10.1.199     YES NVRAM  up                    up
From 10.10.24.2 ( Router)
phoenixvsez#sh ip interface brief
ocol
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              unassigned      YES unset  down                  down
FastEthernet5              unassigned      YES unset  down                  down
FastEthernet6              unassigned      YES unset  down                  down
FastEthernet7              unassigned      YES unset  down                  down
FastEthernet8              unassigned      YES NVRAM  down                  down
GigabitEthernet0           10.10.24.2      YES NVRAM  up                    up
Vlan1                      10.10.0.3       YES NVRAM  up                    up
Hope this helps you to understand my network ,
Hari
Hi Hari,
Could you please provide show ip route from below devices
L3-PHOENIXCORP
phoenixvsez
phoenixcorpoff881
Najaf
Dear Nijaf,
Please find the details below.
L3-PHOENIXCORP#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.10.1.43 to network 0.0.0.0
     172.16.0.0/24 is subnetted, 1 subnets
S       172.16.20.0 [1/0] via 10.10.1.35
S    192.168.99.0/24 [1/0] via 10.10.1.35
     10.0.0.0/24 is subnetted, 15 subnets
S       10.10.0.0 [1/0] via 10.10.1.199
C       10.10.1.0 is directly connected, Vlan1
C       10.10.2.0 is directly connected, Vlan102
C       10.10.3.0 is directly connected, Vlan103
C       10.10.4.0 is directly connected, Vlan104
C       10.10.5.0 is directly connected, Vlan105
C       10.10.6.0 is directly connected, Vlan106
C       10.10.7.0 is directly connected, Vlan107
C       10.10.8.0 is directly connected, Vlan108
C       10.10.9.0 is directly connected, Vlan109
S       10.10.25.0 [1/0] via 10.10.1.35
S       10.10.32.0 [1/0] via 10.10.1.199
S       10.10.33.0 [1/0] via 10.10.1.199
S       10.10.34.0 [1/0] via 10.10.1.199
S       10.10.35.0 [1/0] via 10.10.1.199
S    192.168.6.0/24 [1/0] via 10.10.1.35
S    192.168.1.0/24 [1/0] via 10.10.1.35
S*   0.0.0.0/0 [1/0] via 10.10.1.43
phoenixvsez#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 10.10.24.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.10.24.1
      10.0.0.0/8 is variably subnetted, 9 subnets, 3 masks
C        10.10.0.0/24 is directly connected, Vlan1
L        10.10.0.3/32 is directly connected, Vlan1
C        10.10.24.0/30 is directly connected, GigabitEthernet0
L        10.10.24.2/32 is directly connected, GigabitEthernet0
S        10.10.31.0/24 [1/0] via 10.10.0.1
S        10.10.32.0/24 [1/0] via 10.10.0.1
S        10.10.33.0/24 [1/0] via 10.10.0.1
S        10.10.34.0/24 [1/0] via 10.10.0.1
S        10.10.35.0/24 [1/0] via 10.10.0.1
phoenixcorpoff881#sh ip route
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 11 subnets, 3 masks
S        10.10.0.0/24 [1/0] via 10.10.24.2
C        10.10.1.0/24 is directly connected, Vlan1
L        10.10.1.199/32 is directly connected, Vlan1
S        10.10.2.0/24 [1/0] via 10.10.24.2
C        10.10.24.0/30 is directly connected, FastEthernet4
L        10.10.24.1/32 is directly connected, FastEthernet4
S        10.10.25.0/24 [1/0] via 10.10.1.35
S        10.10.32.0/24 [1/0] via 10.10.24.2
S        10.10.33.0/24 [1/0] via 10.10.24.2
S        10.10.34.0/24 [1/0] via 10.10.24.2
S        10.10.35.0/24 [1/0] via 10.10.24.2
Hari
Hi Hari,
Modify the configuration as below.
On phoenixcorpoff881
no ip route 10.10.2.0 255.255.255.0 10.10.24.2
ip route 10.10.2.0 255.255.255.0 10.10.1.36 or 35
From your configuration im not sure if the next hop is 10.10.1.36 or is it 10.10.1.35. Any ways you can try one by one and check which one will work:-)
Hope that help.
Najaf
Please rate when applicable or helpful !!!
Thanks a lot Najaf , i am able to ping both hosts viseversa , thanks for your extreame help .
Hari
Hi Hari,
Najaf
Ya You are correct Nijaf , thanks for your suggestion and help once again , If possible can i have your personal ID that i can contact you if i need any assistance.
Hari
Hi Hari,
You can send me private message on Cisco Support Community forum. I monitor this more than my emails :-)
Najaf
Thanks Najaf,
I need one more small help from you , as i am able to ping all the IPS in destination hosts ( 10.10.0.x ,10.10.32.x , 10.10.33.x and 10.10.35.x ) now i want to restrict to ping only 10.10.33.x network from 10.10.2.x network , can you guide me how can i fix this as 10.10.33.x network is my cretical servers and i dont want any hit .
Thanks in advance.
Hari
Hi Hari,
Najaf
Hi Najaf,
I have created ACL and able to restrict , thaks for your suggestion .
Hari
