04-11-2013 01:32 PM - edited 03-07-2019 12:46 PM
Good afternoon,
I have a problem with 2 links (1 Gbps each) that form a PorthChannel (2 switches, one at each end). We are paying to a carrier for those links.
The problem is that sometimes one of the 2 links starts flapping (flappings of 1 or two seconds) so then, our applications start losing synchronization.
I need somehow to solve this to shutdown the port that starts flapping.
I want to know if there is a solution (may be udld, or use spanning tree instead of the PorthChannel) that can shutdown the port when the flapping starts.
Thanks.
Cristian.
04-11-2013 02:06 PM
This switch should put it into err-disabled if it's flapping.
Link-flap error
Link flap means that the interface continually goes up and down. The interface is put into the errdisabled state if it flaps more than five times in 10 seconds. The common cause of link flap is a Layer 1 issue such as a bad cable, duplex mismatch, or bad Gigabit Interface Converter (GBIC) card. Look at the console messages or the messages that were sent to the syslog server that state the reason for the port shutdown.
%PM-4-ERR_DISABLE: link-flap error detected on Gi4/1, putting Gi4/ 1 in err-disable state
Issue this command in order to view the flap values:
cat6knative#show errdisable flap-values!--- Refer to show errdisable flap-values for more information on the command.ErrDisable Reason Flaps Time (sec) ----------------- ------ ---------- pagp-flap 3 30 dtp-flap 3 30 link-flap 5 10
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
04-11-2013 03:23 PM
What kind of links are they? Are they fibre or copper?
If you have link flapping, do NOT use UDLD. It'll only make matters worst.
