How to use 3750 L3 Switches to do NAT?
UmoyaNetworks
Beginner
Beginner
I would like to know how to use a Cisco 3750 L3 switch to do NAT with?
Eddy
Edison Ortiz
Hall of Fame Mentor Hall of Fame Mentor
Hall of Fame Mentor
NAT is not supported on those switches.
The only switch to support NAT is the 6500 Series switch.
For NAT purposes, I recommend getting a regular router.
HTH,
__
Edison.
Edison Ortiz
Hall of Fame Mentor
HTH,
__
Edison.
adamclarkuk_2
Enthusiast
Enthusiast
Not sure what you are asking.
Here is the NAT support matrix
hxxp://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
