how to view temperature of a WS-C3750-48PS-S via http access ?
meetnajmi
I have one 3750-48-ps-s s/w with s/w ver as 12.2(25)SEE2 .Version ID: V05
i do have an entry snmp-server enable traps envmon fan shutdown supply temperature status .
I still wonder if this is the correct and enough parameter to view the temp meter on the http access page?or is there something else to be looked into.
Many thanks.
Reza Sharifi
I have not used http to access the switch but according to the command reference guide you have already configured the correct parameters to be send to Network Management System (NMS).
Here is a link to the command reference guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sea/command/reference/cli3.html#wp1944901
Reza
