ā06-07-2010 09:12 PM - edited ā03-06-2019 11:27 AM
I am planning to start using port teaming on a HP DL360 G6 server that is connected to a Cisco Catalyst model 2960. Are there any special configuration that I need to make on the Cisco Catalyst in order for the port teaming on the HP server to work?
Regads,
Solved! Go to Solution.
ā06-07-2010 10:39 PM
That depends upon what kind of teaming you gonna use..
1. Fault tolerance >> No configuration required on switch side, use the same port type access/trunk
2. Transmit Load Balance with FT >> no configuration required on switch side, use the same port type access/trunk
3. Switch assisted FT >> Etherchannel using LACP for bundled ports on switch.
For further reading please go through below link for teaming
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01415139/c01415139.pdf
Hope this helps
Hitesh Vinzoda
Pls rate useful posts
ā06-07-2010 10:00 PM
EtherChannel.
Hope this helps
Hitesh Vinzoda
