We are implementing ISE enforcement and as part of the process we are doing a shut/no shut on the switch ports. We are experiencing problems with HP thin clients loosing network connectivity after this that require a physical power reboot to fix.
Anyone else experienced anything like this and if so what was the resolution. We are also looking at the HP side of things but don't see a pattern.
It seems to only happen on Cisco 2960's.
