02-02-2011 04:34 PM - edited 03-06-2019 03:19 PM
I have a question about using HQF in the 4948E switch.
Is the 4948E capable of supporting HQF? If yes is there a place (link) that I can get that information? Is there a template? What is the IOS level?
If not, why this fuction is not available?
Thank you.
Gilson
Solved! Go to Solution.
02-03-2011 10:22 AM
No form of HQOS is supported on the 4948E or any version of the 49xx switch at this time. There are no plans to implement it either. Out of all of the switches only the metro ethernet switches like the me-3400 and me-3750 (only on the ES ports) support HQF.
-Matt
02-03-2011 10:22 AM
-Matt
