08-31-2022 11:57 AM
Community,
I was reading about a feature in IOS that makes the IP helper-address function "HSRP Aware" by adding the additional argument "Redundancy" to the command (e.g IP helper-address 10.x.x.x redundancy <name>). This feature prevents the duplication of the DHCP request forwarding to the DHCP server, allowing only the HSRP Active router to forward the request. However, when looking at the NX-OS equivalent (IP DHCP Relay command) I don't see this option. Does anyone know if this is an option in Nexus?
https://learningnetwork.cisco.com/s/article/ip-redundancy-virtual-router-groups-vrg-x
Thank you.
03-20-2024 02:26 PM
Did you find anything out about this by chance? I suspect it's HSRP aware by default but don't see anything confirming this.
03-20-2024 02:35 PM
Add new post it is better
MHM
