HSRP between direct connected switched
s76602061
Does below diagrm of HSRP work properly? Any special configuration necessary on L3 Switch?
5 Replies 5
Mark Malone
That looks good , set pcs as vip ip address, make sure hsrp forms and drop 1 of the paired hsrp interfaces at a time and make sure pcs can still break out, only thing is think about using glbp if all cisco gear to make use of all links and switches and be able to load-balance
Thank you very much
Ganesh Hariharan
Diagram dont show interconnectivity between switches, Assuming that has been taken care either directly or via some layer 2 switch.
and the above logical diagram will fit for FHRP.
Hope it Helps..
-GI
Thank you very much.
Glad you got problem solved, helpful if you can mark this thread has answered so that others can be benifitted.
-GI
