Showing results forĀ
Search instead forĀ
Did you mean:Ā
HSRP_DuplicateAdd
asakurahao
Hi sirs,
I would like to ask about HSRP.
Is it possible to have a log that indicates an IP address conflict even with HSRP configured?
Kindly see sample logs:
003180: Aug  1 12:42:02.952 PH: %TAGCON-3-DUP_ADDR_RCVD: Duplicate Address 10.66.1.241 advertised by peer 10.21.1.2:0 is already bound to 10.21.1.1:0
003181: Aug  1 12:42:02.952 PH: %TAGCON-3-TDPID: peer 10.21.1.2:0, TDP Id/Addr mapping problem (rcvd TDP address PIE, bind failed)
003182: Aug  1 12:44:47.664 PH: %TAGCON-3-DUP_ADDR_RCVD: Duplicate Address 10.66.1.241 advertised by peer 10.21.1.1:0 is already bound to 10.21.1.2:0
003183: Aug  1 12:44:47.664 PH: %TAGCON-3-TDPID: peer 10.21.1.1:0, TDP Id/Addr mapping problem (rcvd TDP address PIE, bind failed)
003184: Aug  1 13:26:47.663 PH: %TAGCON-3-DUP_ADDR_RCVD: Duplicate Address 10.66.1.241 advertised by peer 10.21.1.1:0 is already bound to 10.21.1.2:0
003185: Aug  1 13:26:47.663 PH: %TAGCON-3-TDPID: peer 10.21.1.1:0, TDP Id/Addr mapping problem (rcvd TDP address PIE, bind failed)
003186: Aug  1 13:33:47.663 PH: %TAGCON-3-DUP_ADDR_RCVD: Duplicate Address 10.66.1.241 advertised by peer 10.21.1.1:0 is already bound to 10.21.1.2:0
003187: Aug  1 13:33:47.663 PH: %TAGCON-3-TDPID: peer 10.21.1.1:0, TDP Id/Addr mapping problem (rcvd TDP address PIE, bind failed)
Thanks!
Best Regards,
asakurahao
0 Replies 0
