12-14-2006 02:41 AM - edited 03-05-2019 01:20 PM
I have been having trouble setting a backup default gateway here using hsrp, here are the configs, it basically wouldnt work, can anyone let me know if its ok, and show me amendments if poss
thanks
active router
nterface gigabitEthernet 0/0
description Default Gateway Address for xxxx
ip address 10.1.1.199 255.0.0.0
ip address 10.1.1.69 255.255.0.0 secondary
ip address 172.200.101.9 255.255.255.0 secondary
ip address 172.200.102.9 255.255.255.0 secondary
ip address 172.200.103.9 255.255.255.0 secondary
ip address 172.200.104.9 255.255.255.0 secondary
ip address 172.200.105.9 255.255.255.0 secondary
ip access-group 101 in
ip access-group 101 out
no ip proxy-arp
ip accounting output-packets
duplex auto
speed auto
standby 10 ip 10.1.1.1
standby 10 ip 10.1.1.59 secondary
standby 10 ip 172.200.101.1 secondary
standby 10 ip 172.200.102.1 secondary
standby 10 ip 172.200.103.1 secondary
standby 10 ip 172.200.104.1 secondary
standby 10 ip 172.200.105.1 secondary
standby 10 priority 110
standby 10 preempt
standby 10 authentication xxxx
interface gigabitEthernet 0/1
ip address 11.1.1.3 255.0.0.0
ip address 7.1.1.5 255.0.0.0 secondary
ip address 45.0.0.158 255.0.0.0 secondary
ip address 192.228.10.51 255.255.255.0 secondary
no ip proxy-arp
no ip mroute-cache
duplex auto
speed auto
standby priority 110
standby preempt
standby authentication xxxx
standby 10 ip 11.1.1.1
standby 10 ip 7.1.1.1 secondary
standby 10 ip 45.0.0.156 secondary
standby 10 ip 192.228.10.2 secondary
fall over router
interface FastEthernet0/0
ip address 10.1.1.70 255.255.0.0 secondary
ip address 172.200.101.10 255.255.255.0 secondary
ip address 172.200.102.10 255.255.255.0 secondary
ip address 172.200.103.10 255.255.255.0 secondary
ip address 172.200.104.10 255.255.255.0 secondary
ip address 172.200.105.10 255.255.255.0 secondary
ip address 10.1.1.200 255.0.0.0
no ip proxy-arp
duplex auto
speed auto
standby 10 priority 100
standby 10 preempt
interface FastEthernet0/1
ip address 7.1.1.4 255.0.0.0 secondary
ip address 45.0.0.157 255.0.0.0 secondary
ip address 192.228.10.50 255.255.255.0 secondary
ip address 11.1.1.2 255.0.0.0
no ip proxy-arp
no ip mroute-cache
duplex auto
speed auto
standby priority 100
standby preempt
12-14-2006 02:52 AM
Hi Carl
First advice would be using different HSRP groups numbering for every interface (every network). So, for example use "standby 10" for giga0/0 in active and f0/0 in fallover and "standby 11" in giga0/1 in active and f0/1 in fallover.
Hope this helps
12-14-2006 03:08 AM
what benifit woulf this have ? and why would we do this ?
12-14-2006 03:15 AM
With this you will have different HSRP gorups on the router. This will create two HSRP groups which is called as MHSRP and you can configure HSRP load-balancing to pass the traffic using both the routers.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225sec/3750scg/swhsrp.htm#wp1061629
HTH,Please rate if it does.
-amit singh
12-14-2006 03:08 AM
In Addtion to JOSE's post, I will also suggest to change the priority to a higher value on the router interface which you want to be as active. I have see a lots of issue when you have prority set a relatively close vlaue to the HSRP default value which is 100. You have used priority as 110 on the active router, change is to something 200 or 220. The default priority for the HSRP interface is 100 so you dont have to set it manually.
HTH,
-amit singh
12-14-2006 03:30 AM
An alternative (assuming not you're running an old IOS) is to use separate groups for each secondary IP address.
Don't bother with authentication unless you think there is a real likelihood that someone is going to put another HSRP-capable device on your LAN.
Your multinetting seems a little over-complicated - I think your problem may be the fact that you have overlapping subnets on your 0/0 interfaces. I can't see how HSRP would know which one you meant.
You also don't need the preempt on your secondary router (not that it makes any difference).
You haven't detailed the ACLs - I assume ACL101 doesn't block your HSRP traffic?! It isn't immune.
Pleas rate if this helps.
12-14-2006 04:28 AM
thanks for your help, we dont want to load balance as the other router only has 100 mrg ports, this one has gigabit ones, so Will secondary addresses confuse it ?
12-14-2006 08:19 AM
can anyone help here ?
12-14-2006 08:26 AM
Carl,you can use the different HSRP group for secondry addreses just to make the config simple and have every secondry ip assign to a different group.
If you dont want to use it you should be fine with it. Just change the priority command under the interfaces as I suggested in my last post to some vlaue 200/220 and you should be fine with it.
Let me know if you need more help.
-amit singh
12-14-2006 09:00 AM
so config should be ok as it is apart from priority command ? what benifit will using groups have and can you give me example with my config ?
thanks
12-14-2006 09:37 AM
The benefit that you get using the HSRP groups is that you will have a different virtual IP and MAC for each group. Whenever any client from the particular subnet makes an ARP request, virtual mac from each group is send to the host. This will make a proper ARP entry for each group in the router's ARP table. You can then configure HSRP-load-balancing.
If you have only one group under the router interface for all the secondry ip's you have a single Virtual-MAC for all of the subnets. Hence you cannot have a load-balancing configure in this scenario.
HTH,
-amit singh
