HSRP Issue
bansal.ojasvi
Hello All,
I have an HSRP issue. Here's the st standby brief output from my switches.
switch 1
Vl501 51 100 P Active local 172.25.10.253 172.25.10.1
Vl600 60 100 P Active local 172.25.11.253 172.25.11.1
switch 2
Vl500 50 95 P Standby 172.25.10.253 local 172.25.10.1
Vl501 51 95 P Standby 172.25.11.253 local 172.25.11.1
switch 1
ip dhcp pool Vlan501
network 172.25.11.0 255.255.255.0
domain-name vlan501.local
default-router 172.25.11.1
dns-server 159.18.161.34 66.51.99.55
lease 2
switch 2
lease 2
The issue is that, the second switch is giving out the IP addresses from DHCP pool rather than the first router.
Any help would be appreicated.
OJ
Roberto Salazar
Level 8
Level 8
NOt sure why this is an issue both of the routers/switch are doing dhcp server. dhcp request from clients are bcast, naturally if switch gets a request from clients, it will try to assign ip address, it's a dhcp server after all. What is the real issue?
let me check it
sarahr202
Level 5
Level 5
switch 1
switch 2
Vl500 50 95 P Standby 172.25.10.253 local 172.25.10.1 ( hsrp group should be 51 not 50)
Vl501 51 95 P Standby 172.25.11.253 local 172.25.11.1 ( hsrp group should be 60 not 51)
default-router 172.25.11.1 (it should be 172.25.10.1)
switch 1
vlan 501 is on 172.25.10.0 not on 172.25.11.0
Thanks a lot.....I realize what the issue is.
