HSRP moves from Active -> Init when int in port-channel comes back up
JoakimA
Hello
When doing maintenance we had an unexpected outage due to HSRP moving from Active to Init when ONE interface in a port-channel went up after being down for some time:
063116: Mar 25 09:08:09.343 CET: %LINEPROTO-SW1-5-UPDOWN: Line protocol on Interface TenGigabitEthernet6/6/6, changed state to down
063130: Mar 25 09:58:13.811 CET: %LINK-SW1-3-UPDOWN: Interface TenGigabitEthernet6/6/6, changed state to up
063131: Mar 25 09:58:18.944 CET: %LINEPROTO-SW1-5-UPDOWN: Line protocol on Interface TenGigabitEthernet6/6/6, changed state to up
063132: Mar 25 09:58:19.888 CET: %HSRP-SW1-5-STATECHANGE: Vlan666 Grp 1 state Active -> Init
The other interface in the port-channel, and thus the port-channel, was unaffected.
Can anyone understand why we saw this behaviour?
BR
//joakim
If the VLAN 666 have dual path and STP is spanned, you should not encounter the issue.
May be you need to Troubleshooting adding new VLAN for testing and perform the test.
Also you need to co-related all the device Logs - i am sure in this path one of the Link gone blocking mode. when other Link go down, how fast the STP convergence take place , if you using Rapid STP - it will be quick than as expected.
you only provide small information Logs, what is the Full Logs (i am sure you should see 1 or 2 ping logs and should work as expected as per your diagram (until its configured in correctly - so you need to post the config also)
BB
14 Replies 14
M02@rt37
Hello @JoakimA
The reason for this behavior could be related to how HSRP works. HSRP is a protocol used to provide redundancy for IP networks by allowing multiple routers to participate in a virtual router group. One router in the group is elected as the active router, while the others are in standby mode. The active router is responsible for forwarding packets sent to the virtual IP address, while the standby routers monitor the active router and take over its duties if it fails.
When the interface on the active router goes down, the other routers in the HSRP group detect the failure and one of them takes over as the active router. When the interface comes back up, the original active router will have to compete with the current active router to regain its status.
It's possible that the delay in bringing the interface back up caused the HSRP protocol to initiate a state change from Active to Init. This could be due to the HSRP timers, which determine how quickly the routers detect and respond to changes in the network.
With additional information about your network configuration and HSRP settings, It could help us to find the issue.
Best regards
Hello, cheers. I was unclear/wrong about the port-channel, it was down (the box in the other end was moved) but the vlan 666 other port-channel was never affected. So the vlan int was always up. Could something other trigger the move to Init? STP block perhaps as mentioned below?
@JoakimA
Yes, it's possible that the HSRP state change was triggered by STP blocking. If the port-channel was down, STP would have blocked the interface and put it in the Listening and Learning states before forwarding traffic. During the Listening and Learning states, HSRP packets would not be forwarded, and if the standby router did not receive any HSRP packets within the hold-time, it would initiate a state change. This could explain why the HSRP state changed from Active to Init when the port-channel came back up.
Best regards
balaji.bandi
That is expected behaviour, if the HSRP VLAN trasit using same port-channel and if the portchannel shutdown, if VLAN do not have any other path - then we expect HSRP split brain here.(both will go active / active since you do not have communication between HSRP peers.
In this case when you doing maintenance, what i do is -  shutdown Standby side VLAN Interface, so Active will be always active and pass the traffic, if end device can reach the Gateway VIP IP.
BB
Miriamrgreene
Will this solution for our website? https://bmccpa.com/
can you share
show EtherChannel summary
show spanning tree
I think there is STP issue here
I was wrong, Po17 was down and when 6/6/6 came up the Active > Init occured, Po500 was never affected.
17 Po17(SU) LACP Te1/1/1(P) Te6/6/6(P)
500 Po500(SU) LACP Fo1/1/25(P) Fo2/1/25(P)
VLAN0666
Spanning tree enabled protocol rstp
Root ID Priority 50
Address x.x.y
Cost 1000
Port 5766 (Port-channel17)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 4146 (priority 4096 sys-id-ext 50)
Address x.x.x
Aging Time 600
Interface Role Sts Cost Prio.Nbr Type
Po17 Root FWD 1000 128.5766 P2p
Po500 Desg FWD 250 128.5772 P2p
with all above info. let deep dive here
HSRP go from active -> inti when
1- there is better active than it and this also can be via
A- add new active (You confirm that you not add new HSRP router)
B- using track to increase the priority
2- there is split brain as @balaji.bandi  mention above
can I know if your topology is as show below ?
Hello, its more like this, where R2 was the one taken down for maintenance.
BB
Cheers, I will look into the logs, unfortunately they are very sparse but I will focus on the STP.
Många tack!
as @balaji.bandi mention below dual link and STP will not make any issue
but
VLAN0666
Root ID Priority 50
Address x.x.y
Cost 1000
the vlan is 666 and sys-id-ext 50 !!!
can you check this again
I was obfuscating and missed that one!
Thanks for the help!
You need to Looker wider angle than focussing on HSRP. (that will help you not to repeat the same issue when you do maintenance)
BB
