06-04-2009 09:42 AM - edited 03-06-2019 06:06 AM
IP address 224.0.0.2 is reserved for HSRP so, if I do a ping to 224.0.0.2 in a router/switch configured with HSRP only the IPs belonging to the HSRP groups should reply, I am right?
However if I ping that IP I got a SAN replying to the ping.
Could this the cause of an HSRP bouncing between standby/active/standby states?
I have discarded all physical and configuration problems I know.
Cheers
Solved! Go to Solution.
06-12-2009 05:14 PM
If you have a smartnet contract, I suggest opening a case with TAC.
06-04-2009 09:54 AM
Jorge:
[EDIT]
Where does the SAN fit into your topology?
Victor
06-04-2009 10:12 AM
The topology is:
CORE1---HSRP---CORE2
Switch
SAN
The problem I have is that the standby router changes to speak even though the active is up and when it notices the active is up it returns to standby state.
This problem is completely random.
Regards.
06-04-2009 10:36 AM
It sounds as though you are dropping HELLO packets between the core routers. If the active and standby HSRP routers fail to exchange HELLO messages for as long as the default dead timer, the active router will begin the process of going active. However, once the active and standby routers exchange their first HELLO packet, and if preemption is configured on the active router, the standby router should go back to standby.
This is what I am imagining is happening.
Can you show us an example of what is happening?
Victor
06-04-2009 10:43 AM
You can try clearing ARP of the core switches. This is just a suggestion.
As correctly pointed eariler if hello's are missed, seondary router will definitely will make an attempt to become primary router. You can enable debug standy packets on both routers. Which will let you know if you are receiving hellos from neighbor. Then you can pin point the problem.
Subodh
06-04-2009 10:48 AM
Pinging 224.0.0.2 will cause a reply from all multicast capable routers, not just HSRP enabled routers.
Your HSRP instability can be attributed to a number of reasons. Can you provide portion of the config along with a small diagram of the network components on that segment?
Have you check the interfaces for errors on the HSRP device as well as the switch on which these devices are connected?
__
Edison.
06-04-2009 11:02 AM
Hello Jorge,
224.0.0.2 is not reserved to HSRP but it means all routers in subnet.
So pinging 224.0.0.2 you may see answers from devices not running HSRP.
see
http://www.iana.org/assignments/multicast-addresses/
You can check the health of HSRP communication with
sh standby brief on the core devices.
The standby protocol runs on top of UDP, and uses port number 1985.
Packets are sent to multicast address 224.0.0.2 with TTL 1.
see
http://www.faqs.org/rfcs/rfc2281.html
So the fact that another device has answered to 224.0.0.2 it is not a problem for HSRP in the subnet.
Hope to help
Giuseppe
06-04-2009 01:03 PM
Thanks for all the replies. In the attachements is some log entries and configurations.
The topology is:
CORE01--Port-Channel (HSRP)--CORE02
SwitchA SwitchB
SAN & servers Servers
There are no errors in any interface in any switch. STP is stable. No CPU or any other physical problem on the switches.
No packet loss or overload in the links (max. 5% utilization).
Any ideas?
Cheers
06-04-2009 01:06 PM
Sorry the topology cannot be seen properly.
It is the typical:
- 2 cores switches connected via a Port-channel running HSRP for each SVI between them.
- Cores are connected via redundant links to 2 access switches and several servers are connected to these switches.
Regards.
06-04-2009 02:14 PM
Jorge,
Your HSRP timers are quite aggressive and they can be the reason for the HSRP flap. Please raise the HSRP timers to msec 400 msec 1200 and see if it helps.
06-04-2009 02:22 PM
This is the first thing I thought but the network has been working with this timings without any flap for more than 2 years.
And 2 days ago the problem started suddenly. Maybe I should try a reboot of both switches.
Cheers.
06-12-2009 12:28 PM
Could the problem be that all SVIs belong to standby group 1 although some of them have core1 as active and the other ones have core2 as the active router?
I am not sure about that because I think the HSRP group number is local to the interface only.
Any thoughts?
Regards.
06-12-2009 12:36 PM
I doubt the problem is related to the HSRP Group. The HSRP Group is used for the Virtual MAC and the standard virtual MAC address is used: 0000.0C07.ACxy, where xy is the group number in hexadecimal.
All that information remains within the Vlan, so there isn't any conflict with other SVIs using the same group.
__
Edison.
06-12-2009 12:42 PM
Thanks for you answer. We also changed the timers as you suggested, we put the default ones and even then the problem was there. Furthermore, this week the problem is constant and not random so we are thinking about reloading both switches.
Any other thing to check to avoid the reload?
Cheers.
06-12-2009 12:43 PM
Cheers.
