HSRP state Active Active
CSCO11632143
After confguring HSRP in my edge switches HSRP status is showing active in both switches as per my knowledge in HSRP one switch should be active state and other one shoud be in standby, Please let me know your thoughts on this and feel free to ask for more information.
Thank you in advance
Conf
SW1
interface GigabitEthernet2/0/1
description #Primary Link WTBB 1#
no switchport
ip address 10.107.25.11 255.255.255.248
standby 30 ip 10.107.25.10
standby 30 priority 110
standby 30 preempt
SW2
interface GigabitEthernet1/0/1
description # Secondary Link WTBB 2#
no switchport
ip address 10.107.25.12 255.255.255.248
no standby 30 preempt
SW001#show standby
GigabitEthernet2/0/1 - Group 30
  State is Active
    5 state changes, last state change 4w5d
  Virtual IP address is 10.107.25.10
  Active virtual MAC address is 0000.0c07.ac1e
    Local virtual MAC address is 0000.0c07.ac1e (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 0.358 secs
  Preemption enabled
  Active router is local
  Standby router is unknown
  Priority 110 (configured 110)
  IP redundancy name is "hsrp-Gi2/0/1-30" (default)
SW002#show standby
GigabitEthernet1/0/1 - Group 30
  State is Active
    23 state changes, last state change 2d16h
    Next hello sent in 2.454 secs
  Preemption enabled
  Priority 100 (default 100)
  IP redundancy name is "hsrp-Gi1/0/1-30" (default)
8 Replies 8
Harold Ritter
Hi Siju,
This is generally because the two routers cannot reach each other through the interface in question. Most probably a L2 issue.
Mr Harold is correct, this kind of issue happen when both the routers not communicating properly.
check the Ip connectivity as well as physical connection.
Shashi
Hi Harold and Shashi,
Thanks for your replay.Here both ip's are communicating eachother. I have generated new HSRP logs. PFB, HSRP logs and kindly suggest any other troubleshooting steps for resolving the issue.
Nov 20 08:14:10: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Nov 20 08:14:10: HSRP: Gi1/0/1 API Hardware state change - ignore
Nov 20 08:14:10: HSRP: Gi1/0/1 API Software interface coming up
Nov 20 08:14:10: HSRP: Gi1/0/1 Interface UP
Nov 20 08:14:10: HSRP: Gi1/0/1 Starting minimum interface delay (1 secs)
Nov 20 08:14:10: HSRP: Gi1/0/1 API Add active HSRP addresses to ARP table
Nov 20 08:14:10: %SYS-5-CONFIG_I: Configured from console by siju on vty0 (10.1.3.128)
Nov 20 08:14:11: HSRP: Gi1/0/1 Interface min delay expired
Nov 20 08:14:11: HSRP: Gi1/0/1 Grp 30 Init: a/HSRP enabled
Nov 20 08:14:11: HSRP: Gi1/0/1 Grp 30 Init -> Listen
Nov 20 08:14:11: HSRP: Gi1/0/1 Grp 30 Redundancy "hsrp-Gi1/0/1-30" state Init -> Backup
Nov 20 08:14:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
Nov 20 08:14:21: HSRP: Gi1/0/1 Grp 30 Listen: c/Active timer expired (unknown)
Nov 20 08:14:21: HSRP: Gi1/0/1 Grp 30 Listen -> Speak
Nov 20 08:14:21: HSRP: Gi1/0/1 Grp 30 Redundancy "hsrp-Gi1/0/1-30" state Backup -> Speak
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Speak: d/Standby timer expired (unknown)
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Standby router is local
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Speak -> Standby
Nov 20 08:14:31: %HSRP-5-STATECHANGE: GigabitEthernet1/0/1 Grp 30 state Speak -> Standby
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Redundancy "hsrp-Gi1/0/1-30" state Speak -> Standby
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Standby: c/Active timer expired (unknown)
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Active router is local
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Standby router is unknown, was local
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Standby -> Active
Nov 20 08:14:31: %HSRP-5-STATECHANGE: GigabitEthernet1/0/1 Grp 30 state Standby -> Active
Nov 20 08:14:31: HSRP: Gi1/0/1 Grp 30 Redundancy "hsrp-Gi1/0/1-30" state Standby -> Active
Nov 20 08:14:34: HSRP: Gi1/0/1 Grp 30 Redundancy group hsrp-Gi1/0/1-30 state Active -> Active
Nov 20 08:14:37: HSRP: Gi1/0/1 Grp 30 Redundancy group hsrp-Gi1/0/1-30 state Active -> Active
SW002#ping 10.107.25.11
Sending 5, 100-byte ICMP Echos to 10.107.25.11, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
SW001#ping 10.107.25.12
Sending 5, 100-byte ICMP Echos to 10.107.25.12, timeout is 2 seconds:
Siju.
and also  Switches are not getting ARP entry for the peer ip
SW002#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.107.25.10            -   0000.0c07.ac1e  ARPA   GigabitEthernet1/0/1
Internet  10.107.25.12            -   0024.c33b.47c3  ARPA   GigabitEthernet1/0/1
SW001#show arp
Internet  10.107.25.10            -   0000.0c07.ac1e  ARPA   GigabitEthernet2/0/1
Internet  10.107.25.11            -   0024.51f2.51c9  ARPA   GigabitEthernet2/0/1
Siju
You have not told us what platform this is configured on but it looks to be a layer 3 switch. And I note that the ports are configured as layer 3 routed ports and not as switch ports. So it makes it important to know what is physically connected on these switch ports. The output of show cdp neighbor would be very helpful in this.
For HSRP to work it must send a layer 2 multicast which must be received by the HSRP peer. Your output suggests that the multicast is not getting through. The fact that arp is not showing the neighbor also suggests that there is not layer 2 broadcast connectivity between these switch ports. So please inform us exactly of what is physically connected to each of these switch ports.
Rick
Rick
Hi Siju,
Have you checked if there are no flaps/errors that may casue the HSRP to break. In the mean time can you please share the output of the below commands.
I also see that the switch becase standby which means the HSRP worked and suddenly lost the active router , can you tell me how frequently does this flap occur.?
Do you have to shut/no shut one interface to reform the HSRP again ?
SW1
show ip interface gig2/0/1
SW1#ping
Protocol [ip]:
Target IP address: 224.0.0.2
Repeat count [1]:100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Interface [All]: Gig 2/0/1
Time to live [255]:
Source address:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
SW2
show ip interface gig1/0/1
SW1#ping
Protocol [ip]:
Interface [All]: Gig 1/0/1
Time to live [255]:
Source address:
Run the extended pings when the HSRP on both routers are active, this will confirm if the multicast hello packets are being sent and are being replied to by the other switch.
Umesh
Hi Siju,
can you ping 224.0.0.2 when the issue is happening to see if both the switches can respond back?
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
hi,
The logs shows that both the routers are not communicating to each other for hsrp as no hello packet are seen.
please send sh cdo neighbour so that we can get the information about the connectivity.
Shashi
