HSRP Traffic flow
Tarun Vyas
Suppose I have three server in HSRP in vlan-100. Please find attachment for example diagram.
           A) All of server are connected to active and standby switch in vlan 100. ( All server are having teaming).
           B) Suppose only server-3 lost the connectivity from activity switch. (so its standby link will become active)
          => How data will flow from in-side to out-side from Server -3
           A) First server-3 data will go to standby switch and through HSRP link will go to active switch then will go to outside.
        OR
          B) Server-3 pass the in-side to outside traffic directly from standby switch to out-side
mlund
Level 7
Level 7
If it is Nexus switch with vpc config, it will go for option B. Otherwise it's option A.
/Mikael
16 Replies 16
mlund
Level 7
Level 7
/Mikael
@Mlund
I am having cisco 4506 switch.
I spoke with cisco TAC and he told me that option B will work in my scenario.
Can you conform....
I don't think so Option B will work in case of your scenario. Probably TAC engineer is mistaken or you could not understand his statement well.
Thnx guys for your support.
I am having sup module 6 so it does not support VSS and so I am using HSRP.
Now TAC also has conformed that option A will work for my scenario...
Tarun Vyas
Can you conform...
If your 4500s are running VSS then I agree with TAC.
If they are not then as far as I am aware the traffic has to go across the interconnect to the active switch.
Jon
If 4500 with VSS then it means you have only one active Control Plane and one active Data Plane then there is no Active/Backup so this diagram does not work there.
I mean this diagram does not support VSS concept
VSS has one control plane but two data planes ie. both switches can forward traffic so it would work with your diagram.
Jon
I had missed word active but still about your statement confused me.
How diagram supports here VSS
First of all these are not two switches only switch so one Active Control Plane and one Active Data Plane
only in vPC, there are two active control plane and two active data plane.
VSS!! after the configuration, is only one switch not two switches
You keep saying there is one active data plane but there isn't.
With VSS both switches are active in forwarding data which is why your scenario would work with VSS.
Jon
Dear Jon,
Please i will appreciate if you can share any link which is mentioning 2 DP and i will also be clear.
But as per diagram, there are two CP also HSRP and did you ever notice anywhere using VSS and HSRP, then how  diagram can be fit for VSS ? For this i am very much clear
From the VSS Q&A -
Thanks regarding DP, i had one bootcamp for CCIE DC (from ipexpert Rick), trainer had mentioned about difference between vPC <> VSS and he mentioned one CP and one DP in VSS while two in vPC. I will check with him, on what bassis he said so.
Regarding Diagram, for sure it is not suitable for VSS.
Anyway thanks a lot and it was really nice talking to you.
Asif
The diagram should work with VSS as I said and I'm not sure how you can be so certain it would not when 5 minutes ago you thought VSS only had one data plane.
Jon
