Http web not coming on
smavashev
2801 Router
3550 switch
3500 switch
2 2950 switches
2 pc hosts
Basically I have both PC's pinging 4.2.2.2 DNS, Layer 2, Layer 3 intervlan routing functioning, 2801 Nat is translating, able to ping default gateway of ISP and have configured DNS from what ISP has given under my DHCP scope, however Im still not getting, web pages opening up when i open mazzila or firefox ! Any suggestions ?!?!
singhaam007
Level 3
Level 3
Hi Sergei,
could you please try to telnet 4.2.2.2 on port 80 from your machine to see if actually it is opening any connection.?
please rate if this helps.
thanks
cadet alain
can you post config of 2801 and tell us the message you've got from your browsers.
Regards.
Alain
A small diagram and a show running-config could help us get you up and running in minutes.!!!!
Cheers
Rustom Billimoria
