11-13-2019 02:47 AM
Dear All
I have a situation I can't solve.
I have a PC connected to VLan1 routed Via a TRUNCK fiberport to a IE 2000 switch on VLan90
I have a PLC connected to on of the port on the VLan90 switch, works perfect I can work on this from VLan1
But I also have a hub connected to one port, I can see the mac addresses in the switch (all on same port from the hub)
and i can ping the equipment from the switch, but I can't see the equipment connected to the hub from my PC on VLan1
This is my first setup with a hub on a switch and I can't workout what I am missing.
Any help would be great.
/Flemming
11-13-2019 03:47 AM
Hi @Holmux
Could you share a diagram of your network, indicating what is configured in the ports?
11-13-2019 04:18 AM
11-14-2019 12:00 PM
It looks like you need to assign fa1/2 to a VLAN access port. For example, VLAN 90.
11-21-2019 01:11 PM
Were you able to get this issue resolved?
