Huge problems to internal route SA 520W
centellico
I'm trying to be able to access my Webserver inside my network from the inside of the SA 520W router, but i have tried everything and nothing is working.
When i try to write the web URL to my webserver i'm getting https://domainname.com and login for the SA 520W router
Can anyone help out here ?
centellico
I found the answer to how to get this routing issue solved,
Add the IP address to your domain name in the HOSTS file and
example
127.0.0.1           localhost
192.168.2.100    www.yourdomain.com
Next time you enter your domainname in the browser it will not reroute the traffic outbound and inbound but directly with the DNS lookupname in the browser to your local IP adr for your webserver.
Bent
