HWIC certification
charles.e.davis
Does a HWIC (HWIC-D-9esw) have it's own operating system that needs to be Common Criteria Compliant when it is installed into a router, i.e. 2821.  Or does it use the routers operating system and that is the only thing that needs to be certified.  Thanks.
Nagaraja Thanthry
HWIC-9ESW uses router's IOS to operate. It does not have its own operating system. It is just like any other cards on the router.
Hope this helps.
NT
Nagaraja Thanthry
Hope this helps.
NT
