HyperTerminal
sherdilkhan2000
I want to write a script for resetting the CISCO switch, by which I can just copy and paste it on HyperTerminal and Switch is reset and automatically booting, any help will be appreciated.
Milos Megis
Level 3
Level 3
you don´t need script. If you are connected to console and want to reboot switch then type command reload and confirm with enter.
Switch should boot automatically if you didn´t configure manual boot.
However cisco switches should work fine without reset for many months. So I don´t see purpose of this.
