02-14-2011 09:56 PM - edited 03-06-2019 03:33 PM
Hi there,
I have a problem with configuration.
Although the module in second slot is removed in the C6509 , the configuration of the module doesn't disappear on the configuration when I enter show running-config.
We could only solve this problem after rebooting.
What should I do to solve this problem ?
Does not everyone else how to solve ?
- Version : C6K 12.2(18)SXF13
=========================show module ===========================
RT#sh mod
Mod Ports Card Type Model Serial No.
7 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL10478LB0
8 2 Supervisor Engine 720 (Hot) WS-SUP720-3B SAL09475W27
9 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAL09528TFQ
10 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAL09528TFL
11 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAL10360TLY
12 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL095184WR
13 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45 SAL08414V9Q
Mod MAC addresses Hw Fw Sw Status
7 0017.9444.1748 to 0017.9444.174b 5.2 8.4(2) 12.2(18)SXF8 Ok
8 0015.c648.c970 to 0015.c648.c973 4.4 8.1(3) 12.2(18)SXF8 Ok
9 0016.478d.b978 to 0016.478d.b97f 3.1 5.4(2) 8.5(0.46)RFW Ok
10 0016.478d.ba38 to 0016.478d.ba3f 3.1 5.4(2) 8.5(0.46)RFW Ok
11 0018.bafe.a030 to 0018.bafe.a037 3.4 5.4(2) 8.5(0.46)RFW Ok
12 0016.478d.29d8 to 0016.478d.2a07 10.2 7.2(1) 8.5(0.46)RFW Ok
13 0012.4304.1af0 to 0012.4304.1b1f 3.1 5.4(2) 8.5(0.46)RFW Ok
Mod Sub-Module Model Serial Hw Status
7 Policy Feature Card 3 WS-F6K-PFC3B SAL10478K0N 2.3 Ok
7 MSFC3 Daughterboard WS-SUP720 SAL10478L14 2.5 Ok
8 Policy Feature Card 3 WS-F6K-PFC3B SAL0946580Z 2.1 Ok
8 MSFC3 Daughterboard WS-SUP720 SAL09475JK4 2.3 Ok
Mod Online Diag Status
7 Pass
8 Pass
9 Pass
10 Pass
11 Pass
12 Pass
13 Pass
======= THIS CONFIGURATION ======
interface GigabitEthernet2/1
ip address X.X.179.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
logging event link-status
udld port aggressive
interface GigabitEthernet2/2
ip address X.X.179.9 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/3
ip address X.X.179.17 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/4
ip address X.X.179.25 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/5
ip address X.X.179.33 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim dr-priority 100
ip pim query-interval 1
ip pim sparse-mode
interface GigabitEthernet2/6
ip address X.X.179.41 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/7
switchport
switchport mode access
no ip address
interface GigabitEthernet2/8
switchport
no ip address
interface GigabitEthernet2/9
ip address X.X.179.49 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
interface GigabitEthernet2/10
ip address X.X.179.57 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/11
ip address X.X.179.65 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
interface GigabitEthernet2/12
ip address X.X.179.73 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/13
switchport
switchport access vlan 146
no ip address
interface GigabitEthernet2/14
ip address X.X.179.121 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/15
switchport
switchport access vlan 162
no ip address
interface GigabitEthernet2/16
ip address X.X.179.113 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/17
ip address X.X.179.81 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/18
ip address X.X.179.89 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
interface GigabitEthernet2/19
switchport
no ip address
interface GigabitEthernet2/20
switchport
switchport access vlan 155
no ip address
interface GigabitEthernet2/21
switchport
switchport access vlan 156
no ip address
interface GigabitEthernet2/22
ip address X.X.4.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/23
ip address X.X.179.97 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/24
ip address X.X.179.105 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
Solved! Go to Solution.
02-15-2011 04:26 AM
Hi Kwangwon,
I believe this is expected behavior to allow users to replace a faulty module without needing to reconfigure the ports all over again. Good news is that there is a workaround to change this behavior.
You might want to check : http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCed83035&from=summary
| Cat6 still shows information of removed module | |
Symptom: When a module is removed from the chassis physically the configuration for the slot is present.onditions: None Workaround: There is a global configuration command to alter this behavior. conf t#module clear-config If this is configured, the configuration for the slot will be removed when the card is removed from the chassis. If user wants to keep the current behavior, then he can use the following command. conf t#no module clear-confg | |
02-15-2011 04:26 AM
Hi Kwangwon,
02-15-2011 03:41 PM
Hi Kapil Pathak,
I really appreciate your helping. You are the best an engineer.
Have a good day!
