ICMP Port Unreachable from gateway 10.40.25.154 for udp from testserver (10.40.25.175) to 10.20.250.3 port 33440
kumar94437
Sir,
i got this output in Sun Solaris 9server while trying to ping 10.20.250.3 following error message is coming
ICMP Port Unreachable from gateway 10.40.25.154 for udp from testserver (10.40.25.175) to 10.20.250.3 port 33440 what may be the reason.Whether it is server problem or switch Problem.I have attached connectivity diagram.Kindly do the needful at the earliest.
10.20.250.3 is in vlan 1
10.40.25.154 is vlan 2
testserver # ping -s 10.20.250.16
PING 10.20.250.16: 56 data bytes
64 bytes from 10.20.250.16: icmp_seq=0. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=1. time=40152. ms
64 bytes from 10.20.250.16: icmp_seq=2. time=39152. ms
64 bytes from 10.20.250.16: icmp_seq=3. time=38154. ms
64 bytes from 10.20.250.16: icmp_seq=4. time=37155. ms
64 bytes from 10.20.250.16: icmp_seq=5. time=36156. ms
64 bytes from 10.20.250.16: icmp_seq=6. time=35157. ms
64 bytes from 10.20.250.16: icmp_seq=7. time=34158. ms
ICMP Time exceeded in transit from 10.40.20.122
for udp from thirup5med (10.42.20.13) to 10.20.250.16 port 33437
for udp from thirup5med (10.42.20.13) to 10.20.250.16 port 33438
ICMP Time exceeded in transit from 10.42.20.122
for udp from thirup5med (10.42.20.13) to 10.20.250.16 port 33439
ICMP Port Unreachable from gateway 10.42.20.154
for udp from thirup5med (10.42.20.13) to 10.20.250.16 port 33440
64 bytes from 10.20.250.16: icmp_seq=42. time=10036. ms
64 bytes from 10.20.250.16: icmp_seq=43. time=9037. ms
64 bytes from 10.20.250.16: icmp_seq=44. time=8039. ms
64 bytes from 10.20.250.16: icmp_seq=45. time=7040. ms
64 bytes from 10.20.250.16: icmp_seq=46. time=6041. ms
ICMP Port Unreachable from gateway 10.40.20.154
for udp from thirup5med (10.40.20.13) to 10.20.250.16 port 33442
64 bytes from 10.20.250.16: icmp_seq=47. time=5043. ms
64 bytes from 10.20.250.16: icmp_seq=48. time=4044. ms
64 bytes from 10.20.250.16: icmp_seq=49. time=3045. ms
64 bytes from 10.20.250.16: icmp_seq=53. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=54. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=55. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=56. time=0. ms
64 bytes from 10.20.250.16: icmp_seq=57. time=1. ms
64 bytes from 10.20.250.16: icmp_seq=58. time=0. ms
^C
----10.20.250.16 PING Statistics----
59 packets transmitted, 22 packets received, 62% packet loss
round-trip (ms)  min/avg/max = 0/14200/40152
testserver #
Senthil
rwagner
I answered your duplicate question:
https://supportforums.cisco.com/message/3050721
