IE-3300-8P2S can't set the power supply max wattage
pwozney
Hey folks,
These switches take power supplies that are connected by just two wires, so we have to tell the switch how big the power supply is. In the past I've been able to set this with the line "power inline wattage max" but on this switch that command doesn't work.
What am I doing wrong?
It seems like the "power" configuration parameter is completely gone. Has it been renamed?
Thanks!
Anyone found a fix for this?
