10-04-2013 12:57 PM - edited 03-07-2019 03:51 PM
I have a situation where number of ie3000 switches are connected in ring topology and i want to add a spoke switch with a fiber link in trunk mode .
lets say switch A has IEM-3000-8FM= module and one of the ports (lets say f2/1) on this module will be connected to gigaethernet (G1/1) port on the other switch with 100 mb SFP type.
- in global configuration i have # spanning-tree bpduguard enable
- G1/1 is set to full duplex , trunk mode
when i set f1/2 on trunk mode i get both ports in err-disable state, after restarting the port it comes to not connected mode !
i reconfigured f2/1 as access port vlan x , now it works (the link is on although other side is configured as trunk !)
# sh interfaces status gives that port f2/1 is on trunk mode
i will appreciate if somone explains to me why err-disable is happening at the beginning and how come that a port is configured as access port (# sh run gives that it is access ) behaves and operate as a trunk and without coming into err-disable state
regards
10-04-2013 01:09 PM
How are you setting the parameters on each side for the trunk ports?
10-05-2013 12:57 PM
first it was like that:
G1/1: # switchport mode trunk
# spanning-tree bpdufilter enable
# spanning -tree portfast trunk ! i dont want the spoke switch to participate in STP !
f2/1 :
i got err-disable state with above configuration, after clearing the error (shut , no shut) both ports are comming to (not connected) state and stay like that.
when reading error log i see interface is gone to err-disable because of receiving bpdu packet with bpdu guard is enabled (global configuration for the switch on G1/1).
then i did this
f2/1 : # switchport access vlan x
# spanning-tree portfast
Now it is working properly , when i issue (# sh interfaces status ) i got the port f2/1 as a trunk
i am not sure if above configuration is stable (port is sconfigured as access but operates as trunk)
10-07-2013 05:33 AM
Well, if you have bpduguard enabled, then the port leading to the new switch you're adding is going to go in err-disable if the switch you add to the network has a lower spanning tree value then the current root bridge. This is the point of bpdu guard. Now, I see that you have bpdufilter enabled so I can't explain why a BPDU is being sent. Also, it appears dynamic trunking is kicking in.
If all your switches have the default spanning tree priority, the switch you're adding may have a lower mac address. Try raising the spanning tree priority for the vlans configured on the switch you are adding (if you are running a per-vlan spanning tree). Also, don't forget that vlan 1. A lot of people forget about vlan 1. Also, it's bpdu's don't go accross trunks tagged.
For my layer2 domains, I follow the following setup. I'm not saying this is the way to do it, this is just how I do it. Others may do it a different way. As always, test first in a lab any setup you plan to introduce into production.
On my root bridge:
spanning-tree mode rapid-pvst
spanning-tree portfast default
spanning-tree vlan
On my backup root bridge:
spanning-tree vlan
On trunk ports:
switchport
switchport nonegotiate
switchport trunk encap 8021q (may or may not be supported depending on your software version)
switchport trunk allowed vlan add
spanning-tree portfast trunk
Now, if I am going to connect a switch to another switch and I'm not going to use spanning tree, I will actually do a no spanning tree per each vlan on that switch. However, I keep very tight control over the ports on my network. I don't disable spanning tree on any switch users connect to. The only time I will disable spanning tree is if the switch I'm connecting will only be used for a special purpose. Also, I keep all non-user ports in my switch environment admin down.
Now, some people have much larger networks where this may be impossible. Therefore, keeping your layer2 domain consistant is very important. I like keeping control over which vlans cross trunks but some folks prefer a more dynamic setup.
