IGMPv3 source specific l2 forwarding
Andreas Reimann
Hi there
Does Cisco Switches Support a Feature to flood multicast traffic specific on a given source
Assumption
Client A an Vlan A sends IGMPv3 Join for Group A from Source A
Client B an Vlan A sends IGMPv3 Join for Group A from Source B
Client A should not receive traffic from Source B and Vice versa
The Output for igmp Groups on Cisco shows no source address specific Information, while Huawei does. Problem is that outgoing Interface can easily be overloaded with traffic not required by the Client.
Most probably Huawei goes beyond RFC specification, can Cisco do that as well and on what HW/SW?
show ip igmp snooping groups
Vlan      Group                    Type        Version     Port List
816       232.255.4.128            igmp        v3          Gi1/0/18, Gi1/0/48,
                                                           Te1/0/2
816       232.255.7.128            igmp        v3          Gi1/0/13, Gi1/0/14,
                                                           Gi1/0/35, Gi1/0/36,
                                                           Gi1/0/41, Gi1/0/43,
                                                           Te1/0/2
display igmp group static
Static join group information
Total 2 entries, Total 2 active entries
Group Address     Source Address    Interface   Expires
225.0.0.10        0.0.0.0           Loop1       never
232.1.1.20        10.0.0.1          Vlanif3     never
Rich Uline
Andreas,
If you issue the command 'sh ip igmp group', you should see the source IP address.
Client A and Client B are in the same VLAN. Therefore they should and will receive all multicast traffic sent by the other.
This is a something you will have to consider when designing your network to support multicast. If the multicast application(s) require more bandwidth, then you need to design accordingly.
Also, I'd like to invite you to take a look at this multicast explanation which I recently read. I think it might help you.
I‘m aware about theoretical basics, i‘m asking because another switch vendor implemented that feature. The question was, if Cisco products also allow L2 port filtering of multicast based on source IP
The answer can be yes or or no.
Thank you
Andy
