Ikev ipsec problem
TaniaKanth85411
Frequent Visitor
Frequent Visitor
Hi.
please please please help, i need to configure a ip sec tunnel on my asa 5505, it isnt working, i know i am missing something, please help
hostname ciscoasa
names
interface Ethernet0/0
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 20.20.30.0 255.255.255.224
interface Vlan2
nameif outside
security-level 0
ip address 100.100.200.1 255.255.255.248
interface Vlan3
no nameif
no security-level
no ip address
object network inside-net
subnet 20.20.30.0 255.255.255.224
access-list ikev1-list extended permit ip 20.20.30.0 255.255.255.224 10.10.10.0 255.255.255.128
nat (inside,outside) dynamic interface
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
crypto ipsec ikev1 transform-set ikev1-set esp-aes esp-sha-hmac
crypto map ikev-map 1 match address ikev1-list
crypto map ikev1-map 1 set ikev1 transform-set ikev1-set
crypto map ikev1-map interface outside
crypto ikev1 enable outside
crypto ikev1 policy 1
encr aes
authentication pre-share
group 2
tunnel-group 100.100.200.1 type ipsec-l2l
tunnel-group 100.100.200.1 ipsec-attributes
ikev1 pre-shared-key this_is_a_key
sorry for the delay:
13 Replies 13
Seb Rupik
Hi there,
you need to configure a NAT exemption rule to ensure that the the traffic destined to the IPSec peer site is not translated when it is routed via the 'outside' interface, this means it will be picked up by the crypto map ACL.
object network REMOTE_SITE_01
  subnet 10.10.10.0 255.255.255.128
nat (inside,outside) source static inside-net inside-net destination static REMOTE_SITE_01 REMOTE_SITE_01 no-proxy-arp route-lookup
You also have two crypto maps configured both with incomplete config:
crypto map ikev1-map 1 match address ikev1-list
You also appear to have no peer IP configured:
crypto map ikev1-map 1 set peer ?.?.?.?
cheers,
Seb.
Hi, i have just tried it, but i wont work? 😞  plus the peer is that the inside for my vlan on the other side or the outside? and is it the same process on both sides?
And do i need to delete this part??
This is what it is saying
object network Remote_site_01
ciscoasa(config-network-object)#subnet 10.10.10.0 255.255.255.128
ciscoasa(config-network-object)#nat (inside,outside) source static inside-net inside-net destination static REMOTE_SITE_01 REMOTE_SITE_01 no-proxy-arp route-lookup
% Invalid input detected at '^' marker.
ciscoasa(config-network-object)#nat (inside,outside) source static inside-net inside-net destination static REMOTE_SITE_01 Remote_site_01 no-proxy-arp route-lookup
ciscoasa(config-network-object)#exit
ciscoasa#conf t
ciscoasa(config)#nat (inside,outside) source static inside-net inside-net destination static REMOTE_SITE_01 Remote_site_01 no-proxy-arp route-lookup
ciscoasa(config)#
ciscoasa(config)#nat (inside,outside) source static inside-net inside-net destination static remote_site_01 no-proxy-arp route-lookup
ciscoasa(config)#nat (inside,outside) source static inside-net inside-net destination static Remote_site_01 no-proxy-arp route-lookup
This is the confgiration on the other firewall
ASA Version 8.4(2)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
no nameif
no security-level
no ip address
inspect icmp
telnet timeout 5
ssh timeout 5
encr aes
group 2
Seb Rupik
Hi there,
The peer IP is the is typically the IP address of the interface on which the ctypto map has been applied.
Regarding your config error, it is case sensitive. You have created the object 'Remote_site_01' so use exactly that object name in the NAT statement:
nat (inside,outside) source static inside-net inside-net destination static Remote_site_01 Remote_site_01 no-proxy-arp route-lookup
cheers,
Seb.
i am so sorry, but i dont get it.
Plus do i need the same confgirtion on the other side for this to work?
Plus what do you mean by
 You also have two crypto maps configured both with incomplete config?
sorry for the connfussion
In your original config you have a typo:
which gives you two crypto maps: ikev-map and ikev1-map .
Replace the first line with:
To fix the issue.
cheers,
Seb.
I cat overwrite anything, is there a command which deletes the crypto map from the asa firewall, i tried typing no infront but it keeps saying
no crypto map ikev1-map 1 set ikev1 transform-set ikev1-set
% Incomplete command.
Just type:
...you will end up with:
crypto map ikev1-map 1 match address ikev1-list crypto map ikev1-map 1 set ikev1 transform-set ikev1-set crypto map ikev1-map interface outside !
...but it will work.
cheers,
Seb.
#crypto map ikev1-map 1 match address ikev1-list
ERROR: unable to locate access-list ikev1-list
Add the following ACL and it should take without error:
The remote side will need identical configuration except the peer IP will need changing and the crypto ACL and NAT exception statement will need reversing; swapping the source and destination address around.
Hi.
It still wont take it,
i have pasted the file now
Hi, i now kow its the acl - the configuration look like this now, but i still wont take
interface Vlan1
nameif inside
security-level 100
ip address 10.10.10.0 255.255.255.128
interface Vlan2
nameif outside
security-level 0
ip address 100.100.100.1 255.255.255.248
object network local
route inside 192.168.10.0 255.255.255.0 10.10.10.253 1
route inside 172.16.10.0 255.255.255.0 10.10.10.253 1
route outside 0.0.0.0 0.0.0.0 100.100.100.2 1
access-list ikev1-list extended permit ip 172.16.30.0 255.255.255.192 10.10.10.0 255.255.255.128
access-list ikev1-list extended permit ip 192.168.40.0 255.255.255.192 10.10.10.0 255.255.255.128
telnet timeout 5
ssh timeout 5
encr aes
hash md5
group 2
