10-06-2011 09:42 AM - edited 03-07-2019 02:38 AM
I want to use a SFP module in one of the slot # 5 or # 6 instead of the supervisor engine. Is it possible?
10-06-2011 09:48 AM
If you are using a sup720 then you have to use slot 5 for the supervisor, you have no choice.
Slot 6 can be used for a redundant supervisor but if you don't have one then yes you can use it for your SFP module.
Jon
10-06-2011 10:01 AM
Thanks Jon.
