11-05-2015 10:41 PM - edited 03-08-2019 02:35 AM
Hi All ,
Briefly I have I-BGP session between R1 lo0 & R3 lo0 that advertise Loopbacks from two routers , although I can see R3 Lo3 appeared in R1 routing table and via reverse for R3 , I can not initiate BGP session between R1 Lo1 and R3 Lo3.
debug indicated below ,
*Mar 1 05:27:37.750: BGP: 30.30.30.30 active open failed - no route to peer, open active delayed 34813ms (35000ms max, 28% jitter)
I think BGP can not estabilsh relationship with other peer learned via BGP , It shall be learned via any IGP . Is that true ?
| interface Loopback0 ip address 1.1.1.1 255.255.255.255 ! interface Loopback1 ip address 10.10.10.10 255.255.255.255 ! interface FastEthernet0/0 ip address 192.168.1.1 255.255.255.0 duplex auto speed auto ! router bgp 1 no synchronization bgp log-neighbor-changes network 10.10.10.10 mask 255.255.255.255 neighbor 3.3.3.3 remote-as 1 neighbor 3.3.3.3 update-source Loopback0 neighbor 30.30.30.30 remote-as 1 neighbor 30.30.30.30 update-source Loopback1 no auto-summary ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 ip route 3.0.0.0 255.0.0.0 2.2.2.2 |
interface Loopback0 ip address 3.3.3.3 255.255.255.255 ! interface Loopback3 ip address 30.30.30.30 255.255.255.255 ! interface FastEthernet0/1 ip address 192.168.2.3 255.255.255.0 duplex auto speed auto ! router bgp 1 no synchronization bgp log-neighbor-changes network 30.30.30.30 mask 255.255.255.255 neighbor 1.1.1.1 remote-as 1 neighbor 1.1.1.1 update-source Loopback0 neighbor 10.10.10.10 remote-as 1 neighbor 10.10.10.10 update-source Loopback3 no auto-summary ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 ip route 1.1.1.1 255.255.255.255 FastEthernet0/1 |
| R1#show ip route Gateway of last resort is 0.0.0.0 to network 0.0.0.0 1.0.0.0/32 is subnetted, 1 subnets C 1.1.1.1 is directly connected, Loopback0 S 3.0.0.0/8 [1/0] via 2.2.2.2 10.0.0.0/32 is subnetted, 1 subnets C 10.10.10.10 is directly connected, Loopback1 C 192.168.1.0/24 is directly connected, FastEthernet0/0 30.0.0.0/32 is subnetted, 1 subnets B 30.30.30.30 [200/0] via 3.3.3.3, 00:18:01 S* 0.0.0.0/0 is directly connected, FastEthernet0/0 |
R3#show ip route Gateway of last resort is not set 1.0.0.0/32 is subnetted, 1 subnets S 1.1.1.1 is directly connected, FastEthernet0/1 3.0.0.0/32 is subnetted, 1 subnets C 3.3.3.3 is directly connected, Loopback0 10.0.0.0/32 is subnetted, 1 subnets B 10.10.10.10 [200/0] via 1.1.1.1, 00:19:34 C 192.168.2.0/24 is directly connected, FastEthernet0/1 30.0.0.0/32 is subnetted, 1 subnets C 30.30.30.30 is directly connected, Loopback3 |
11-05-2015 10:42 PM
R1# show ip bgp summary
BGP router identifier 1.1.1.1, local AS number 1
BGP table version is 5, main routing table version 5
2 network entries using 240 bytes of memory
2 path entries using 104 bytes of memory
3/2 BGP path/bestpath attribute entries using 372 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
Bitfield cache entries: current 1 (at peak 1) using 32 bytes of memory
BGP using 748 total bytes of memory
BGP activity 3/1 prefixes, 3/1 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
3.3.3.3 4 1 254 252 5 0 0 03:52:59 1
30.30.30.30 4 1 0 0 0 0 0 never Active
R1#
