Inconsistent Mask and Address Error
Johmon171
can someone please explain why I am receiving this error message?
OficinaCentral(config)#ip route 192.168.10.64 192.168.10.65 255.255.255.224
%Inconsistent address and mask
OficinaCentral(config)#ip route 192.168.10.96 192.168.10.97 255.255.255.224
OficinaCentral(config)#ip route 192.168.10.128 192.168.10.129 255.255.255.240
OficinaCentral(config)#ip route 192.168.10.144 192.168.10.145 255.255.255.240
OficinaCentral(config)#ip route 192.168.10.160 192.168.10.161 255.255.255.248
OficinaCentral(config)#ip route 192.168.10.168 192.168.10.169 255.255.255.248
OficinaCentral(config)#ip route 192.168.10.176 192.168.10.177 255.255.255.248
johnlloyd_13
Level 9
Level 9
hi,
the format for static route should be:
ip route <destination network> <subnet mask> <next-hop-ip>
kindly also check your subnetting.
semakabid1
Hello
The problem is pretty straight forward in your case.
you are entering the static route in wrong format. consider the following ip router  entry as sample
ip route 192.168.1.192 255.255.255.224 192.168.1.66
192.168.1.192 === destination network to reach
255.255.255.224 === destination subnet mask
192.168.1.66 ===  ip address of next hop
you can also specify the exit interface to reach the destination.
Hope it will help  :D
i am new to networking please correct me if someone find any mistake in answer.
