10-17-2014 06:30 AM - edited 03-07-2019 09:09 PM
I have couple of Cisco 6509 configured in VSS.
I would like to take soft reboot of individual switch one at a time.
Kindly suggest the commands to do the same.
Regards.
10-17-2014 07:15 AM
To reload only the VSS standby chassis, use command - redundancy reload peer...
To redundancy reload VSS active chassis, first initiate a VSS switchover by command - redundancy force-switchover... Then, when switchover occur, and standby chassis become active use command - redundancy reload peer...
10-17-2014 08:02 AM
Thank you for the kind reply.
Regards.
