input errors keep increasing
maher
Level 6
Level 6
Hi there,
I've configured my router c7200 and run VLAN 802.1q. At the main trunk, I noticed on my switch Cat 2924 XL, from the sh interface output, the input error keep increasing tremendously. Below is the output:
cat2924#sh int fa0/1
FastEthernet0/1 is up, line protocol is up
Hardware is Fast Ethernet, address is 0006.28ca.b241 (bia 0006.28ca.b241)
Description: To Router1
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 237/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 3d13h
Queueing strategy: fifo
Output queue 0/4096, 0 drops; input queue 0/4096, 0 drops
30 second input rate 385000 bits/sec, 65 packets/sec
30 second output rate 237000 bits/sec, 86 packets/sec
117386815 packets input, 4070930013 bytes
Received 30763 broadcasts, 109224489 runts, 0 giants, 0 throttles
109224683 input errors, 194 CRC, 0 frame, 288 overrun, 1082 ignored <*****
0 watchdog, 30763 multicast
277054073 packets output, 3004700553 bytes, 0 underruns
0 lost carrier, 0 no carrier
cat2924#sh run int fa0/1
Building configuration...
Current configuration:
interface FastEthernet0/1
description To Router1
load-interval 30
duplex full
speed 100
switchport mode trunk
no cdp enable
hold-queue 4096 in
hold-queue 4096 out
end
Router1#sh run int fa1/0
Current configuration : 189 bytes
interface FastEthernet1/0
description To Cat2924
ip address 192.168.1.1 255.255.255.252
ip route-cache flow
load-interval 30
duplex full
no cdp enable
end
Router1#sh int fa1/0
FastEthernet1/0 is up, line protocol is up
Hardware is DEC21140A, address is 0003.e408.981c (bia 0003.e408.981c)
Description: To Cat2924
Internet address is 192.168.1.1/30
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Last input 00:00:08, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d17h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6251
Output queue: 0/40 (size/max)
30 second input rate 298000 bits/sec, 74 packets/sec
30 second output rate 397000 bits/sec, 75 packets/sec
205069384 packets input, 4157277182 bytes
Received 726 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
171072169 packets output, 2110671796 bytes, 0 underruns
My question, what makes the input errors keep on increasing? Is it indicate a problem that need to be resolve?
Need your expert advise.
Thank you very much.
maher
vladrac-ccna
Level 9
Level 9
usually:duplex mismatch, bad cables or NIC problems.
Vlad
Vlad,
Thanks for the suggestion. I will try have a look and troubleshoot to norrow down the problem. BTW, for duplex mismatch, I sure that from the sh interface command full-duplex 🙂 perhaps bad cables or port fast-interface NIC problems?
thanks.
maher
glen.grant
Usually wiring problems specially it looks like one side is clean and the other is not . Also i have never seen a hold queue command on a layer 2 switch I think I would get rid of those 2 commands off that interface.
Hi Glen,
I think on the Cat2924 right, the wiring problems seems not clean? Not the Router right? Regarding the hold-queue not sure, but if I remove the command no service impact perhaps? Maybe used to buffer the packet in queue ...
thanks.
maher
