Installing DSP from 2600 series into 2600xm series
antonio.vazquez
I have a doubt and I don't know if this possible.
Can I install a DSP (PVDM) from a 2600 series router into a 2600xm series router?
7 Replies 7
Giuseppe Larosa
Hello Antonio,
you have a PVDM or PVDM2?
two different generations of DSPs exist for cisco routers so your question is wise.
Hope to help
Giuseppe
Thank you for your response Giussepe.
Sincerenly, I don't know exactly how can I discover what type of PVDM I have?
'sh voice dsp'
Check out DSP TYPE in the output.
I've already known it, but my problem is that the original router has crashed and I cannot execute this command.
If I connect this DSP, is there any risk?
I highly doubt you'll "fry" anything. If I were you I'd just try and see. Do you see any writing on the PVDM's at all?
When you tell "fry anything", what is anything?
PVDM?
Router?
Don't take my word for it but I doubt you'll ruin the router or the PVDM. Why don't you compare models on the DSP Calculator? http://www.cisco.com/cgi-bin/Support/DSP/cisco_configure.pl
You can plug in both of your router types and go from there.
