Highlighted
Beginner
inter-vlan acl doesn't work but vlan maps works in 4507
acl to deny any ip communication between two different vlans (different ip network) in cisco 4507 switch doesn't work but when the same acl is applied by vlan maps then it works perfectly. please clarify ?
1 REPLY 1
Highlighted
Advisor
Re: inter-vlan acl doesn't work but vlan maps works in 4507
Shouldn't matter. Can you post the ACL? Is it applied in or outbound?
HTH, John *** Please rate all useful posts ***
Content for Community-Ad
