Inter-Vlan Routing Configuration
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-15-2015 06:31 AM - edited 03-08-2019 12:33 AM
I am configuring a Cisco 2960C switch for inter-vlan routing and can't seem to get it working. I have set the gateway of last resort as my routers eth1 interface ip (192.168.1.1) and the vlan shows up in the routing table but I cannot ping from a pc or get any type of vlan routing.
I have a static route set up on the router with a destination of the vlan in question using 192.168.1.1 as its next hop. Obviously something is not configured correctly, so what am I missing??
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2015 07:09 AM
What are the two vlans..have you configured SVI for them in switch? Or are you using Router on Stick where everything going to ur router ?
Share configuration.
Madhu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2015 07:23 AM
Here are some configurations.
SW1#show vlan br
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Gi0/1
Gi0/2
2 Data active
3 Voice active
4 IP-Camera active
5 WiFi active
99 Management active Fa0/8
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
SW1#show ip int br
Vlan1 192.168.1.2 YES NVRAM up up
Vlan2 192.168.0.1 YES manual up down
Vlan3 192.168.3.1 YES manual up down
Vlan4 192.168.4.1 YES manual up down
Vlan5 192.168.5.1 YES manual up down
Vlan99 192.168.99.1 YES manual up down
FastEthernet0/1 unassigned YES unset down down
FastEthernet0/2 unassigned YES unset up up
FastEthernet0/3 unassigned YES unset up up
FastEthernet0/4 unassigned YES unset up up
FastEthernet0/5 unassigned YES unset down down
FastEthernet0/6 unassigned YES unset down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset down down
GigabitEthernet0/1 unassigned YES unset up up
GigabitEthernet0/2 unassigned YES unset down down
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2015 07:30 AM
Are you trying to route between vlan 1 and 99?
What are your pc's gatway addresses which are not able to ping each other?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2015 07:44 AM
I think I've had a breakthrough. I had configured an incorrect default gateway for the pc. In this case the 192.168.99.0 network. After I configured the default gateway to 192.168.99.1 on the pc I was able to connect.
If you could elaborate it would be welcome. I'm still not sure I fully understand the concept. I'm going to check a couple of other things and post my findings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2015 07:48 AM
When you create 2 SVI (in this case vlan 1 and 99), the switch enables routing between these vlans by default. If you do a
sh ip route
on switvh you can see these 2 subnets are known to switch over vlan 1 and 99.
So all you need to do is ensure your pc have right gateway adresses to send packets for remote subnets.
Hope this helps.
******** Please rate all useful posts*******
Madhu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2015 03:07 PM
This is incorrect, this would be true for a layer 3 switch, which the 2960 isn't.
To achieve what you are looking for you need to configure ROAS, basically a trunk is configured between the two and then you create a sub interface for each VLAN.
Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2015 03:24 PM
@Martin, unless I'm mistaken, when the 2960C's ios is upgraded to version 15.2.3E1 it is capable of some L3 routing, i.e. it keeps a routing table. I believe static routing only but would have to check on that.
I'm pretty sure I have the router performing inter-vlan routing as I speak. If you check the cisco boards and google there is documentation. It just needs to have the correct ios version.
Can anyone definitively confirm or deny?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-15-2015 08:57 PM
Share us a
sh ver
sh ip route
From 2960
Madhu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2015 02:59 AM
Version is as above, 15.2.3E1. I updated it myself from 12.2, specifically for the (limited) L3 capability.
I will post the output from ip route this evening.
Many thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2015 01:36 PM
@Madhu, here is the version output (truncated):
SW1#show version
Cisco IOS Software, C2960C Software (C2960c405-UNIVERSALK9-M), Version 15.2(3)E1, RELEASE SOFTWARE (fc3)
and here is the ip route output:
SW1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.1.1
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan1
L 192.168.1.2/32 is directly connected, Vlan1
192.168.99.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.99.0/24 is directly connected, Vlan99
L 192.168.99.1/32 is directly connected, Vlan99
I do not have a trunk line configured, which I thought was necessary for router-on-a-stick.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2015 02:55 PM
With the right software it can perform basic L3 functionality, which is limited to 16 static routes, it cannot perform inter-vlan routing.
Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-16-2015 03:49 PM
It may just be semantics but when a host in one vlan can communicate (ping) with a host in another vlan...that is inter-vlan routing, however basic it may be. At least that's how Cisco defines the term.
It will not do routing protocols and it is limited to 16 static routes, so that is correct but router-on-a-stick is not necessary with this particular switch and ios version.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-17-2015 03:08 AM
You said you have a router, so this is would do the routing, thats why I said you need to configure ROAS. (in which case you wouldn't need L3 functionality on the switch)
At the moment you have one active SVI, i.e. VLAN 1. This historically was the case with this switch, hence why I didn't think it would be possible. However, I have had a look and it appears this has been changed, so thats the first thing to look at.
Martin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-17-2015 04:08 AM
Apologies Martin. Interface vlan 99 was down because I didn't have anything attached to it at that time. I really should have had it up before I posted.
Thanks for your contributions and insights too. It is very much appreciated.
