ā04-15-2022 04:02 AM
I have created 3 vlans and enabled inter vlan connection between switches and end Pcs by trunk ports. Now i am trying to access router 0 from router 1 through ssh but it keep giving me error
Connection timed out; remote host not responding. in both routers have configured vlans . please help to ping these two routers
ā04-15-2022 04:55 AM
Difficult to say with only the diagram but are the router's fa0/0 interfaces in the same vlan as they seem to be using IPs from the same subnet.
If they are as long as you have allowed that vlan across the trunk link it should work.
If they aren't then you need to rethink your IP addressing on the routers.
Jon
ā04-15-2022 06:20 AM
i added router 1 and server in vlan 3 and made their ports access. then i ping router 1 with 0 with ip address of vlan3 and it goes well.
ā04-16-2022 02:02 PM
attach your PT file here in a zip format so that we can check this out.
Regards, ML
**Please Rate All Helpful Responses **
ā04-17-2022 12:39 AM
ā04-17-2022 01:08 AM
I opened your file, neither router has any SSH configuration. What command exactly are you using on Router1 to access Router0 through SSH ?
