08-28-2013 05:25 PM - edited 03-07-2019 03:11 PM
I'd put this on the getting started board, but it's too weird:
I'm deploying to a site that will have a single ISP-assigned address. This connection will be used by users on the LAN for standard internet access, and by two dedicated multicast sources. ISP has provided two mcast group addrs and a pimv2 RP address.
With nat-outside turned off on the WAN interface, the router appears as a pim neighbor on the upstream router, but regular internet connections don't work through the switch ports.
Turn nat-outside on, connectivity is restored, but the pim relationship is broken (neighbor disappears upstream).
I've got a cheap soho gateway that could easily handle NAT for the LAN connections. Would possible to assign an interface to only that device, and somehow bypass the need for NAT in the router?
thanks
Solved! Go to Solution.
08-29-2013 11:17 AM
Okay, this is where I'm confused, and may be the cause of the issue. You have a route map matching everything, so here's what I want you to try and possibly fix the issue:
ip access-list extended NAT_ACL
permit ip 10.10.10.0 0.0.0.255 any
deny ip any any
route-map MAP_ACL permit 10
match ip address NAT_ACL
See if that fixes the issue. You have an acl to tie the internal subnets for natting, but you don't have it applied to your route map. The router defaults to natting everything because the route-map is permitting everything that's coming through it.
HTH,
John
*** Please rate all useful posts ***
08-28-2013 05:59 PM
I don't think putting another device in the mix should be necessary. Is the rp a public address? Can you post your nat config?
HTH,
John
08-28-2013 06:15 PM
Thanks for the fast reply! RP is hosted at the ISP. A little backstory: the only reason for the Cisco is that nothing else I could find in the price range supported pim. Otherwise it would have just been the little netgear gw.
Here's the relevant-looking chunk from the config:
interface FastEthernet8
description ILIGHT
ip address xx.xx.201.100 255.255.255.0
ip pim sparse-mode
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description INTERNAL NETWORK
ip address 10.10.10.1 255.255.255.0
ip pim sparse-mode
ip nat inside
ip tcp adjust-mss 1452
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip pim rp-address 199.8.216.31
ip pim send-rp-announce FastEthernet8 scope 16
ip pim send-rp-discovery scope 16
ip mroute 0.0.0.0 0.0.0.0 xx.xx.201.97
ip msdp peer xx.xx.201.97
ip msdp cache-sa-state
ip nat inside source route-map MAP_ACL interface FastEthernet8 overload
ip route 0.0.0.0 0.0.0.0 xx.xx.201.97
deny ip any any
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
Message was edited by: OBRIAN CHILDS (to mask IPs)
08-29-2013 07:41 AM
I labbed this up and I don't lose peering when enabling nat. Can you post the rest of your route-map being used for natting? I'm assuming that the only thing there is that you're matching on the NAT_ACL. Have you tried updating the ios on the router?
HTH,
John
08-29-2013 10:14 AM
Thanks again for chasing this, John!
Version is 12.4(22r)YB3. Also, the setup (I'm not native to cisco or routing) is a mashup of first getting pim out, then finding out there would only be one LAN address and scrambling to get commodity access up. I'm hoping I've missed something obvious.
Here's what I paste after doing a factory reset:
en
conf t
!------------------------GLOBAL
ip multicast-routing
ip route 0.0.0.0 0.0.0.0 199.8.201.97! <<----------------UNIQUE
ip mroute 0.0.0.0 0.0.0.0 199.8.201.97! <<----------------UNIQUE
hostname ITHOR
ip name-server 8.8.8.8
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
!------------------------WAN
interface f8
ip address 199.8.201.100 255.255.255.0! <<----------------UNIQUE
Description ILIGHT
ip nat outside
ip pim sparse-mode
!------------------------LAN
interface vlan1
Description INTERNAL NETWORK
ip nat inside
ip pim sparse-mode
no shutdown
!------------------------OTHER
ip access-list exten NAT_ACL
deny ip any any
route-map MAP_ACL
ip nat inside source route-map MAP_ACL interface fa8 overload
interface range f0-7
no shutdown
no banner exec
no banner login
end
wr
08-29-2013 10:48 AM
No problem! Can you post the running config in its entirety? Remove passwords, logins, and addressing information...
HTH,
John
08-29-2013 11:08 AM
In all its glory. Currently: yes to inet access, no to showing as a pim neighbor upstream.
ITHOR#sh running-conf
Building configuration...
Current configuration : 4248 bytes
! Last configuration change at 18:21:44 UTC Thu Aug 29 2013 by cisco
! NVRAM config last updated at 18:06:03 UTC Thu Aug 29 2013 by cisco
version 15.1
hostname ITHOR
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-63307560
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-63307560
revocation-check none
rsakeypair TP-self-signed-63307560
crypto pki certificate chain TP-self-signed-63307560
certificate self-signed 01
30820227 30820190 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
2F312D30 2B060355 04031324 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 36333330 37353630 301E170D 31333038 32393138 30333139
5A170D32 30303130 31303030 3030305A 302F312D 302B0603 55040313 24494F53
2D53656C 662D5369 676E6564 2D436572 74696669 63617465 2D363333 30373536
3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100CCE8
B4A6FF6D B2229931 519302F9 4A401302 D264F085 D864B35F 794DADB7 B158A1A4
39E14911 0B972824 662C1C2E DE19EC25 B6EAB0F0 517FDCCB 773F0CF3 DB0F19D5
7372A257 45CD3265 2840D01E 98503611 D581B824 8261AF85 8FADF6CA 7785B71D
81F64295 76AFF090 C53890CD 6B8E33C6 E45BAFE3 DE9D38C9 C0F61AD3 BBE30203
010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603 551D2304
18301680 14885E66 10B89547 1E13804C E8127BA4 0FC97F83 3C301D06 03551D0E
04160414 885E6610 B895471E 13804CE8 127BA40F C97F833C 300D0609 2A864886
F70D0101 05050003 8181005B 3C38EF12 963A4BC9 AC9C93FE 8B2A8AF5 4627CBE0
BCC0A071 FA0ED92E E5010F15 B212FD9D F720622D 9D41CEF5 86962DCE 5E772083
A4AF1F7B FE03873A 46C750B1 8E899D1D 1263787B 320F7416 9DA8EAB6 F73C7A7F
C5D29E94 BD24813F 8EEB6779 497061AC 8F54F28B C8465C35 F353360A 4F63926E
26FCB8C2 F90EFC4B 289523
quit
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO891-K9 sn FTX163886MG
username XX privilege 15 secret 4 XX
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
description ILIGHT
ip pim sparse-mode
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip pim sparse-mode
ip nat inside
interface Async1
no ip address
encapsulation slip
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip pim rp-address xx.xx.216.31
deny ip any any
no cdp run
control-plane
mgcp profile default
line con 0
login local
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
ITHOR#
08-29-2013 11:17 AM
deny ip any any
HTH,
John
08-29-2013 11:29 AM
THAT DID IT!
Thank you so much. This thing's been kicking my ass for a week.
(and double thanks for the description of what was happening)
08-29-2013 11:30 AM
Never a problem...glad to help
HTH,
John
