interface continues to go up / down
Bruce Summers
I have a question concerning a Cat 3750.
Presently, I have a couple VLAN's configured on this LAN switch. We only have 1 user on the switch (planned for many more). I have the following VLAN's configured:
VLAN 200 managment
VLAN 201 User VLAN
I have an up link to an aggregation switch via a layer 3 PO (PO3)
My problem is this.
If the single user removes his desktop from the switch, the VLAN Interface goes into an Up / Down state until such time as a host is plugged back into the switch.
any thought on why this would be?
thanks
Bruce
Richard Burts
Bruce
It is the expected behavior of the switch that if a VLAN has no active device connected (or is not connected to an active trunk) that the VLAN will go to a down state. Over time, as you get more users connected to the VLAN this issue should take care of itself.
Rick
Rick
s.marino
Do you have this user port set as:
switchport mode access
spanning-tree portfast
or is it set to the defaults out of the box?
I also agree with Rick.
Sal
