Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
I recently replaced a stack of switches with C9300s and encountered an interesting UDLD issue. After reviewing with seniors on my team, it seems it may have had something to do with the order of operations.Switches were uplinked via two 10G SR optics...
Guardian452 by Community Member
  • 136 Views
  • 4 replies
Hello everyone,Here is my problem :%SYS-4-CHUNKSIBLINGSEXCEED: Number of siblings in a chunk has gone above the threshold. Threshold:10000 Sibling-Count:45558 Chunk:0x20EB71D0 Name:Elsinore TSIP P -Process= "GNSS Periodic Process", ipl= 0, pid= 92Ver...
mika-cisco by Level 1
  • 2293 Views
  • 11 replies
Hi Experts,Need your help one more time I am configuring EEM script for switches backup but i facing below errorsConfigured command - action 25.0 cli command "copy running-config ftp://CISCOSWITCH:Passwd@192.168.10.10/SWITCH/IN/$h/$h-$t abc.txt"Error...
surazb by Level 1
  • 182 Views
  • 6 replies
Resolved! IP Source Guard
So, I am having some issue with configuring ip source guard. Here is the configuration results on SW:Switch(config-if)#do sh ip ver soInterface Filter-type Filter-mode IP-address Mac-address Vlan--------- ----------- ----------- --------------- -----...
Can someone help me figure this out?  Unable to ssh from C9300 to a C1000 and it complains about hmac, kex and pretty much everything else.  I am not clear on what I need to change, server/client on either to allow this to work? %SSH-3-NO_MATCH: No m...
Hello,Could you please confirm the C9200L-48P-4, like other C9200 or C9200L can do only DATA stack (StackWise) with C9200L-STACK-KIT, and this not possible to have power stack ?Do you have any Cisco document that specifically mentions that ? I cannot...
Clem58 by Level 3
  • 786 Views
  • 6 replies
We have a stack of 3 IE 9320 switches connected. We tested by powering off each switch and how the end device behaves. While powering off, we see one ping drop and while switch is powered back and then when it gets added to the stack we see intermitt...
grapevine by Level 1
  • 369 Views
  • 6 replies
GreetingsI have a Cisco 9300X running IOS 17.09 and I have a case where I would like to capture RSPAN traffic from another switch but also capture traffic from the local switch. The capturing device only has one monitoring interface, otherwise this w...
hoffa2000 by Level 3
  • 2172 Views
  • 11 replies
Very good day pros.I have STIGs compliance to upgrade 9200 (Stack2 switches) from current IOS (cat9k_lite_iosxe.17.12.05.SPA.conf) to (17.12.06). I have have uploaded (cat9k_lite_iosxe.17.12.06.SPA.bin) and waiting for for the scheduled down time.My ...
