01-08-2013 06:03 AM - edited 03-07-2019 10:58 AM
Hope somebody can help me - I have an issue with intermittant issues of no Audio while on calls.
I have IP handsets on a remote site working off an 881 router they are connected back to the PBX to the head office over a Private MPLS Cloud and there us another 881 router in the headoffice. While a calls will ring without any issues and the Majority of calls are Perfect (No Jitter etc..) some calls will ring but when answered theres no sound. If the user puts the call on hold and takes it back the call is fine again. Im guessing theres some issue here with RTP but I cant tell what im missing on my config of both routers.
The is a dedicated Voice link and no data. the VPN is done over the WAN link to the other site so theres no much configuration on the Router. Configs below I have removed the wan addreses and passwords -
REMOTE SITE - IP PHONES
version 15.1
no service pad
hostname Lavelle_Rathmines_Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.100.100 172.16.100.200
ip dhcp pool DHCP
network 172.16.100.0 255.255.255.0
default-router 172.16.100.1
dns-server
ip cef
ip name-server
ip name-server
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FCZ1646C1Q8
archive
log config
hidekeys
interface FastEthernet0
switchport access vlan 100
switchport trunk native vlan 100
no ip address
speed 100
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport mode trunk
no ip address
interface FastEthernet4
description *Link to Hatch*
bandwidth 5000
ip address 1.1.1.1 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
interface Vlan1
no ip address
interface Vlan100
ip address 172.16.100.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat sip-sbc
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source list 101 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip sla 1
icmp-echo 172.16.200.1 source-ip 172.16.100.1
frequency 5
ip sla schedule 1 life forever start-time now
access-list 1 permit 172.16.200.0 0.0.0.255
access-list 101 permit ip 172.16.100.0 0.0.0.255 172.16.200.0 0.0.0.255
control-plane
line con 0
exec-timeout 30 0
privilege level 15
logging synchronous
login local
line aux 0
line vty 0 4
exec-timeout 30 0
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
MAIN SITE - PHONE SYSTEM
version 12.4
no service pad
hostname Lavelle_Hatch_Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 172.16.200.1 172.16.200.50
ip dhcp pool DHCP
network 172.16.200.0 255.255.255.0
default-router 172.16.200.1
dns-server 83.147.160.2
ip cef
ip name-server 83.147.160.2
ip name-server 83.147.160.130
no ipv6 cef
ip sla 1
icmp-echo 172.16.100.1 source-ip 172.16.200.1
frequency 5
archive
log config
hidekeys
Description *Link to Rathmines*
bandwidth 5000
speed 100
full-duplex
interface Vlan1
ip address 172.16.200.1 255.255.255.0
ip nat inside
interface Vlan100
ip address 192.160.160.1 255.255.255.248
ip nat inside
no ip http server
ip nat sip-sbc
ip nat inside source static 172.16.200.2 interface FastEthernet4
control-plane
line con 0
exec-timeout 30 0
privilege level 15
logging synchronous
login local
no modem enable
line aux 0
line vty 0 4
exec-timeout 30 0
privilege level 15
login local
end
Any help would be greatly appreciated
J-P
