Internal power supply is declared unavailable when the 3750G connect to RPS
boueng
Hi Everyone,
After upgraded Cisco 3750G switches to IOS Version 122-55.SE7, the output of "show env all" showing the built-in power is unavailable.  If we remove RPS, the switches show built-in is good, see the output below.  I wonder has anyone seen this?  It looks like a bug to me.
Disconnect RPS: .............................................
Cisco3750G-01#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 32 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 55 Degree Celsius
Red Threshold    : 65 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  Built-in                                         Good
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
RPS Connected: ..............................................
FAN is OK
TEMPERATURE is OK
1  Built-in                                         Unavail
1   Active          <>
Thank you..
Reza Sharifi
It could be a bug, because even when the RPS is disconnected, the output is not correct.
It should show something like this:
Try a different version and test again.
c3750#sh env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 23 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
1A  C3KX-PWR-350WAC     xxxxxxxxxxxx OK              Good     Good     350/0
1B  C3KX-PWR-350WAC     xxxxxxxxxxxx OK              Good     Good     350/0
1   Not Present     <>
c3750#
I have the same behavior on C2960S-48TS-L and C2960S-24TS-L running 12.2(58)SE2.
One connected to a RPS is showing
GSFRDCE-SW091#sh env power
1  Built-in                                         Unavail
And another one without RPS is showing :
GSFRDCQ-SW091#sh env power
1  Built-in                                         Good
Did anyone find some solution. i have the same issue on WS-C2960S-48TS-L with 152-2.E8
br
