Internet Speed
muneef81
Frequent Visitor
Frequent Visitor
hey all
I have Xfinify modem/router with 600MB download i did conncent a gig Cisco 1921 router to be my defalt gateway and i connected to cisco router cisco gig switch 3750G, my problem here when i connect my computer to xfinity router i will get the full 500 mb download, but when i connect my pc to the Cisco switch or router i am gettting 250 md only, why am not getting the full speed when i am connected to my cisco switch and router ?
H1B#show ip int brief
Interface                                              IP-Address OK?          Method                              Status                     Protocol
Embedded-Service-Engine0/0            unassigned YES          NVRAM                              administratively down down
GigabitEthernet0/0                              10.0.0.84   YES           DHCP                                 up                                up
GigabitEthernet0/1                              172.20.0.1 YES           NVRAM                               up                                up
Serial0/1/0                                          unassigned YES          NVRAM                               administratively down down
GigabitEthernet0/0/0                           unassigned YES          unset                                   down                        down
GigabitEthernet0/0/1                           unassigned YES          unset                                   down                        down
GigabitEthernet0/0/2                          unassigned YES           unset                                   down                        down
GigabitEthernet0/0/3                          unassigned YES           unset                                   down                        down
NVI0                                                   unassigned YES          unset                                  administratively down down
Vlan1                                                 unassigned YES          unset                                    down                        down
Vlan20                                               172.20.1.1 YES          NVRAM                                 down                        down
Vlan99                                              unassigned YES            unset                                   down                        down
H1B#show run
Building configuration...
Current configuration : 2558 bytes
! No configuration change since last restart
version 15.2
hostname H1B
boot-start-marker
boot-end-marker
enable secret 4 9x4aQYg4ZVk1FUMaleimpgDuciy.gApNdVdNbwt4R0fgw8wffw
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
ip cef
ip dhcp excluded-address 172.20.0.1 172.20.0.10
ip dhcp excluded-address 172.20.1.1 172.20.1.10
ip dhcp pool LAN
network 172.20.0.0 255.255.255.0
default-router 172.20.0.1
dns-server 75.75.75.75 4.2.2.2
ip dhcp pool WIFI
network 172.20.1.0 255.255.255.0
default-router 172.20.1.1
ip domain name cisco.com
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX173985GZ
username it secret 4 9g4oYgZbVk1FUMale5impgzDuciy.gApN5dVdNbw9t4R0fg2w
redundancy
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.20.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
interface GigabitEthernet0/0/0
switchport access vlan 20
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
switchport trunk native vlan 99
switchport mode trunk
no ip address
interface Vlan1
no ip address
interface Vlan20
ip address 172.20.1.1 255.255.255.0
ip nat inside
interface Vlan99
description Native
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 2 interface GigabitEthernet0/0 overload
access-list 2 permit 172.20.0.0 0.0.0.255
access-list 2 permit 172.20.1.0 0.0.0.255
access-list 2 deny any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password bob
login local
transport input all
line vty 5 15
password bob
login local
transport input all
scheduler allocate 20000 1000
ntp server 216.239.35.0
end
6 Replies 6
balaji.bandi
check the throhghtput report of your model.
BB
Richard Burts
There are multiple things that might impact the speed that you get. When you tested was your PC connected to a switch port or connected directly to router? If there was possibly a duplex mismatch it would impact the speed. Would you post output of show interface for both router Ethernet interfaces? Running services like nat will have some impact.
Rick
Georg Pauwen
on a side note, you need a default route. Add the below to your configuration:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
Hello
Just like to add I think could be down to the the switch throughput port capability i've not checked it on yet but I wouldn't be surprised on 3750 if it to can full duplex any more then 250mb on a gig interface.
Kind Regards
Paul
Although the 3750G cannot support wire speed on all ports, it should be able to easily support gig on a single port.
The 3750G has a 32 Gbps fabric, sufficient for 16 gig (duplex) ports at line rate. It also provides 38.7 Mpps, which would support 26 Gbps. The fabric will be the performance bottleneck.
Joseph W. Doherty
The most likely bottleneck is your router. Since you're doing PAT on it, take particular notice to table 6 in the reference that Balaji provided. Also take notice of the 1921's CPU performance history when you hit your maximum obtainable download speed.
