Showing results forĀ
Search instead forĀ
Did you mean:Ā
Intersite Switch routing
Lakhvinder Singh
Community Member
Any recommendation/solution is appreciated. I can't share running config but i will provide any information which may be needed. I have attached similar network diagram
I am having 2 sites with dual switch stack of 3850 at each site.
Site A and SiteB are connected through routed port channel uplink (IP 10.48.35.48/30)
Site A has 2 VLAN
vlan 4 (172.12.192.32/27: Vlan IP 172.12.192.62)
vlan 8 (10.48.30.0/28 : Vlan IP 10.40.30.14)
Server1 IP :172.12.192.33
Server2 IP :10.48.30.1
Site B has 2 VLAN
vlan 4 (172.12.194.32/27: Vlan IP 172.12.194.62)
vlan 8 (10.48.32.0/28 : Vlan IP 10.48.32.14)
Server1 IP :172.12.194.33
Server2 IP :10.48.32.1
Now requirement is that Site A servers Should be able to reach Site B server so i added static routing on both switches
Site A
ip route 172.12.194.32 255.255.255.224 10.48.35.50
Site B
ip route 172.12.192.32 255.255.255.224 10.48.35.49
From Server1 , i am able to ping VLAN4 IP successfully (172.12.192.62)
Switch from Site A is pinging VLAN 4 IP of Site B(172.12.194.62) and vice versa
However the Server1 is not able to Ping VLAN4 IP of Site B and Server3 as well.
Same is for VLAN8
if you can ping 172.12.192.62 but not 172.12.192.33 it looks like you have not got the gateway setup on the server please check the IPV4 configuration on the server.
