InterVLAN routing issue
Simonlee2112
Community Member
Hello, i am having trouble getting 2 PC to ping each other on 2 differnent vlans that i have set up on my cisco 3750x
there is vlan 10 - ip address 192.168.10.1
PC1 that is connected to this is 192.168.10.2 - 255.255.255.0 - 192.168.10.1
and vlan 20 - ip address 192.168.20.1
PC2 that is connected to this is 192.168.20.2 - 255.255.255.0 - 192.168.20.1
i have got ip routing enabled
From the switch i am able to ping all devices
When i turn the windows firewall off PC1 is able to ping PC2 but when it is turned back on even with file and printer sharing enable the ping requests time out.
What firewall exception do i need to enable in order to get ICMP working? incase there is something i havent done in the switch the running-config is below
Building configuration...
Current configuration : 3749 bytes
! Last configuration change at 19:17:23 UTC Thu Mar 16 2017
version 12.2
no service pad
hostname HomeSW01
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750x-48
system mtu routing 1500
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
switchport access vlan 10
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
switchport access vlan 20
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
......(cut to save space).....
interface GigabitEthernet1/0/48
no switchport
ip address 192.168.1.254 255.255.255.0
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip helper-address 192.168.10.2
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip helper-address 192.168.20.2
interface Vlan30
ip address 192.168.30.1 255.255.255.0
ip helper-address 192.168.30.2
interface Vlan151
ip address 192.168.151.1 255.255.255.0
ip helper-address 192.168.151.2
interface Vlan152
ip address 192.168.152.1 255.255.255.0
ip helper-address 192.168.152.2
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
line con 0
line vty 5 15
end
Reza Sharifi
You may have a firewall software on your PCs installed/enabled that is blocking ping.  Disable the firewall and try again?
