intervlan routing rip
garytan231
i need help here guys , i have this school assignment and my teacher asked us to do intervlan routing using rip i've done the configuration like routers,switches and the routing but somehow when i tried to connec pc from router 1 to other router's pc it won't work , can anyone help me check what is missing ? thank you
Joseph W. Doherty
The problem you have is you're using Class C subnets and RIP is classful only.
So, you either need to change your network allocations to use Classful networks or, as @MHM Cisco World already suggested, use RIPv2, which does support Classless networks.
Which approach to use depends on whether your school assignment really intends for you to use just RIP or either RIP or RIPv2.
Use rip ver.2
And make sure the gw is correct config in each host
Joseph W. Doherty
